Machine Shop Called
Old Feb 28, 2002 | 06:54 PM
ddn's Avatar
ddn
Default Machine Shop Called
$1069.66
Is it true you can sell ********* for a load of cash in California?
They did a lot of work though:
Hone
Deck
Align Hone
Hot Tank
Cam Bearings
Resize Rods
Grind valve seats (2.19/1.88)
3-angle valve job
Machine valve guides for PC seals
Balance rotating assembly
[Modified by ddn, 5:46 PM 2/28/2002]
Old Feb 28, 2002 | 07:20 PM
bence13_33's Avatar
bence13_33
Default Re: Machine Shop Called (ddn)
That seems reasonable. My bill came to $700 for:
* Bore My 454 +.060"
* Hone The Cylinder Walls
* Magnaflux The Block, Heads & Crank
* Hot Tank The Block, Heads & Crank
* Check The Crank For Straightness
* Polish The Crank Journals
* Check The Surface Area Of Block & Heads
* Install New Cam Bearings & Freeze Plugs
* Resurface Flywheel
* Balance My Rotating Assembly
Why did you have your crank turned down? As long as it's quality work I don't mind them making a few extra bucks on me.
P.S. Keep the ********(s) you may need it/them down the road
:D
[Modified by bence13_33, 5:22 PM 2/28/2002]
Old Feb 28, 2002 | 07:47 PM
ddn's Avatar
ddn
Default Re: Machine Shop Called (bence13_33)
I'm retarded, didn't have them grind the crank. Got a new crank.
Old Feb 28, 2002 | 07:48 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I think Kidneys sell for a good coin. :lol:
Old Mar 1, 2002 | 08:15 AM
mountainmotor's Avatar
mountainmotor
Hey Bud,Speaking of retarded,I just got back with the new Vette.Stopping every 125 miles for Friggin gas!Not a chance for the old butt to get sore doing that!
I got your mail.Yeah,those cam boxes are kinda cool.Those guys were grinding cams for Big Daddy way back!
I have been on the look out for a manifold and carb for you.You might have to bite the bullet and buy new.Carbs just keep getting more expensive.I guess just keep watching ebay till last minute although a annual local swap meet is coming up in March.Might find what you need there.
Are the heads coming soon?
PS.Don't sell those body parts.You will need them at the top of 4th gear!
To Machine Shop Called
