Help with planning my parts...
My car is a '73 350 CI - L82, stock hydraulic camshaft. I don't rev it over 6000 RPM.
Oil pan is new, with a FelPro one piece gasket.
Note that at this point, I have not purchased anything.
I am thinking about changing the following parts :
Harmonic balancer,
Timing chain and gears,
Timing chain cover & pointer
Why I want to do this :
Harmonic balancer is 37 years old, so I think it's time for a new one...
When I removed the oil pan 6 months ago, I noticed some timing chain stretch, about 10 mm, so same conclusion as above...
I do NOT intend to change :
Camshaft,
Water pump.
I do not intend to remove :
Engine block !
Camshaft,
Radiator ( I've got electric fans, so no fan shroud ).
Let's begin with the tools :
I chose Summit Racing Harmonic Balancer Installation/Removal Tool # SUM-G1025 :
http://www.summitracing.com/parts/SU...5/?image=large
I hope it'll make the job easy !
The harmonic balancer :
I want to keep the same diameter ( 8" ) as the stock unit.
This part seems correct for my application :
Pioneer Automotive 872003 :
http://www.summitracing.com/parts/PI...3/?image=large
Of course, I will change the bolt and washer too :
ARP 134-2501 :
http://www.summitracing.com/parts/AR...1/?image=large
Now, the timing chain and gear set. I don't need to advance or retard camshaft timing, but who knows, if I change the camshaft later, it could be an interesting option.
Here, I have a lot of choices, but this part looks fine:
Edelbrock 7800 :
http://www.summitracing.com/parts/EDL-7800/?image=large
And the camshaft lock plate & bolts,
Summit Racing # SUM-G1792 :
http://www.summitracing.com/parts/SU...2/?image=large
I hope this aluminum timing chain cover will fit the previous Edelbrock 7800 kit :
Edelbrock 4240 :
http://www.summitracing.com/parts/EDL-4240/?image=large
I also selected this adjustable timing pointer, even if the Edelbrock 4240 kit includes its own pointer :
Summit Racing SUM-163600 :
http://www.summitracing.com/parts/SU...0/?image=large
Now, the parts I'm not sure I need to buy :
Do I need a cam button spacer ? Is it already included with the timing cover ?
Some of them are made of steel, roller, others are made of solid aluminum...
Summit Racing SUM-G001 :
http://www.summitracing.com/parts/SUM-G001/?image=large
Summit Racing SUM-G003 :
http://www.summitracing.com/parts/SUM-G003/?image=large
Can anyone confirm that the 3 keyways ( allowing to set +4°, -4° or stock timing ) are included with Edelbrock 7800 kit ?
Will the Edelbrock 4240 timing chain cover fit my stock water pump ?
Do I need to buy something else ?
Will everything fit together ?
Any advice would be greatly appreciated...
Thanks in advance.
-i would say buy a romac balancer...piece of beauty and lasts forever . forget timing tape or dial back timing lights-these things come with every degree marked in easy to read markers and numbers.
-timing chain i would buy a rollmaster torrington double roller timing chain.
http://www.romac.com.au/
-even though your running a standard hydraulic i would buy the cloyes timing cover with the cam button adjustment so that if you go roller down the track its there.
(i hate buying things twice if i can help it.)
http://www.cloyes.com/HighPerformanc...S/Default.aspx
-balancer instillation tool is perfect and exactly what i use. this makes it a breeze.
-as for your choice of cover im not sure if it will clear but i cant see why not. if it didnt then it would be unusual and no cam button required if its not a roller cam.
just the usual gaskets , seals and vaseline for dampner installation and i think your in business.as an extra note after 5 minutes of running even a new timing chain will stretch..seems like its loose but its not. i think its just more of a periodic part to replace but generally if its a quality timing chain it will last years.
Do Not need cam button or torrington timing set. Neither do you need lock plate but it's cheap & easy to install.
The suggested australian parts are Very good; but note many pioneer dampers also mfg australia.
Note: most aftermarket steel covers don't fit pan correct, most aluminum don't fit short/vette waterpumps so well. Suggest keep your OE cover OR get a real good race Steel cover from CVProducts.com ... that's a real race supplier ... they also sell romac rollmaster & cloyes
For this, me thinks this timing set as good or better than edel but less $, plenty good for your use
http://www.summitracing.com/parts/CLO-9-1100/
Both cloyes 91100 & edel 7800 timing sets do have 3 keyways.
FYI, if you install timing set in advanced position, your stock L82 cam will gain a bit of low-to-mid range torque but will lose a bit of hi-rpm performance.
As said, all chains stretch rather quickly.
The pioneer damper you picked is degreed, as good or better than OE & plenty good for your use.
If you really must have an adjustable pointer, this will work fine & less $.
http://www.summitracing.com/parts/MRG-4598/
The Edelbroke timing cover notice says they sell the product with two special water pump gaskets thicker than stock,
so they should give enough clearance from ( short ) water pump to cover.
However, I won't probably buy the parts before Christmas, so it lets me some time to think about it...
