trans slips when cold?
Old Nov 30, 2009 | 10:42 AM
glarior's Avatar
glarior
Default trans slips when cold?
I have not checked the fluid today but I will when I drive home.. if it stops pouring down rain. TH350 trans and she was slipping in reverse and felt like it in 1st too. Once warmed up there was no problem. I have blown 2 TH350's in my 85 monte I use to have. If I remember correctly reverse/1st was first to go out :-( However, could it have anything to do with the modulator valve? From an earlier post about the trans said I need to replace that valve. Think that could be the problem?
Old Nov 30, 2009 | 01:53 PM
jimvette999's Avatar
jimvette999
The neoprene lip seals, when old, tend to not be pliable until warm/hot. This lets the pressurized fluid leak by instead of applying the drum. It's been my experience that the lip seals are the cause of slow engagement when cold assuming the fluid level is full. The modulator and or vacuum affects the up/down shift and not engagement. They make an additive that will soften the lip seals but I don't recommend its use. I believe it to be lacquer thinner or something similar.
Old Dec 1, 2009 | 09:31 AM
glarior's Avatar
glarior
That’s good to know.
I checked the fluid and it is low. Go figure its raining again but I will add some today.
My new question is.... Am I able to add ambient temp trans fluid to the hot transmission or should I wait until the trans is at ambient temp too?
Old Dec 1, 2009 | 09:45 AM
noonie's Avatar
noonie
If it truly is from the seal hardening then an ounce of brake fluid will help. At that point, you don't have much to loose.
Old Dec 2, 2009 | 12:34 PM
jimvette999
Makes no difference... I guess you know to check on level ground in park engine running.
Never heard of that trick....what's in brake fluid that helps?
Old Dec 2, 2009 | 12:38 PM
glarior's Avatar
glarior
Yep, it even says to do that on the trans dip stick.
I added some trans fluid last night and will check again when the car is warmed up later today. See if that helps.
To trans slips when cold?
