ok in a little bind here , my stock original wiper motor was covered in paint and junk so i removed it and cleaned well. problem is when i put back in it doesnt work, not that it is a big deal i dont take out in the rain, but you never know. problem is i maybe swapped a wire around, it has three places to plug in , the ground that goes under a screw on the cover, the 3 prong hook up that takes the green yellow and blue, that is a no brainer and on mine it has a single prong above the 3 prongs. i went to my neighbors and he only has the 3 prong line. not the one above it. hope i didnt fry the motor not marking them and pic or info will help thanks
You find the schematic, test for running the motor, and just about anything you could need. If you don't figure it out.. Post again! We'll get you fixed.
ok i looked over that file and i think i have a ground issue (not one) i just hope when i hooked up wrong it didnt fry the motor , what i have is another terminal on top of the 3 pin connector . i think the 2 black wire connector goes there, that just has the ground left, i will study on it and get back thanks for the help, if anybody has a pic of the hookup please post
No other wires are needed on the three pin connector. Use only the three wires green, yellow and blue on this connector. Just the three running to the connector. There is a picture of this on the page link I gave you. I think it's on page four.
The ground wire (4 in the picture) is from the blower motor hooks to a terminal connector on the bolt for the washer pump.
If your car has an alarm there will be a black wire coming from the hood switch that goes to the wiper motor and then the wiper ground plugs into the alarm ground plug. Maybe the black ground is missing and has fallen down out of site.
