hood clearance question
Old Dec 4, 2009 | 10:09 AM
rbat's Avatar
rbat
Default hood clearance question
Thanks in advance for your help
I am building a 383 and am trying to choose a manifold. I will be using the Q-Jet and am ok with a "low profile" type air cleaner.
How do you confirm you have a L88 hood. The person I bought the car from said it was, but I need to make sure before I make a descision on the manifold.
Also, I am open to any suggestions for the build.
1975 original 350, 373 gears, 400 tranny, double hump heads, stock Q-jet carb, Eagle stroker kit, true duals without cats, not sure about which headers yet.
My goal is a nice reliable driver on pump gas with app 400 hp
I know matching components is the secret, my biggest questions are the hood clearance (manifold) cam, manifold and headers
Old Dec 4, 2009 | 11:49 AM
Ganey's Avatar
Ganey
You could post a pic. of your Vette & we can tell if it has a L-88 hood or you can look at other pics.
Med. rise 73-79 hood is only 7/8" lower than L-88 hood & all of these allow cowl induction.
To run the Q-J, you need an air filter that fits w/ hi rise intakes or the low rise Performer like 2101 will even work w/ stock air cleaner.
The 73-79 med. rise hood allows the hi rise intakes like Victor Jr, RPMs & others on SB w/ aftermarket dropbase filter & Holley.
Old Dec 4, 2009 | 05:49 PM
rbat's Avatar
rbat
I tried to post a pick but they are too big (12 mega pix) and I cannot figure out how to post it.
my hood it looks like the yellow one below.
change of plans though, I will be going with typhoon manifold (pc-2020 from skip white performance) and holley 750DP "if" it will fit.
again, I am ok with modifying the air cleaner if necessary
thanks again
Old Dec 4, 2009 | 09:56 PM
SteveG75's Avatar
SteveG75
For a 383 and a Q-Jet, use the Performer RPM Q-Jet, part #7104. The stock air cleaner will not fit but a Moroso Low Profile Racing Air Cleaner with a 3" tall filter will result in about 3/4" clearance with a stock hood. An L-88 hood will have more clearance.
Here are pics of my engine with that manifold and aircleaner, all under a stock '75 hood. Only thing I had to do was dimple the aircleaner base for the accelerator pump arm.
Here is an older photo of the engine with the lower Edelbrock Performer 2101 that allows use of the stock aircleaner.
Photo showing stock hood:
Old Dec 5, 2009 | 01:39 AM
rbat's Avatar
rbat
Thanks Steve,
Can you give me some input on how your 383 performs (build specs and HP and how the car handles the HP)
I don't want a 1/4 mile car, but a dependable, nice driver with as much power that is reasonable for an otherwise stock car.
thanks again
Old Dec 5, 2009 | 02:06 AM
snoopykissedlucy's Avatar
snoopykissedlucy
Along this same set-up....is the Edelbrock RPM intake the same height as the Edelbrock RPM Air-Gap?
I assume it is but you know what happens when you assume!
Old Dec 5, 2009 | 05:48 AM
Ganey's Avatar
Ganey
Yes.
Old Dec 5, 2009 | 06:40 AM
69small block's Avatar
69small block
Default clearance
Go get a can of playdough set on air cleaner and close hood then measure the height of playdough that will give you how much clearance you have to work with with your current setup
Old Dec 5, 2009 | 10:41 AM
rellim51's Avatar
rellim51
I thought the air gap was taller?
Old Dec 5, 2009 | 10:50 AM
Ganey's Avatar
Ganey
SB RPM & RPM Air-Gap are same height.
SB Performer Air-Gap is about 1/4" taller than Performer.
Old Dec 5, 2009 | 11:28 AM
rellim51's Avatar
rellim51
You are correct, as per Edelbrock's web site the RPM and Air Gap RPM are the same height.
Old Dec 5, 2009 | 05:32 PM
SteveG75's Avatar
SteveG75
Originally Posted by rbat
Thanks Steve,
thanks again
No 383 here. Just a roller cammed 350 with Edelbrock heads. Car is still a lot of fun to drive but I am itching to change things up a bit. Maybe LS3 or even BBC swap.
Old Dec 5, 2009 | 10:16 PM
rbat's Avatar
rbat
Default right number
how much HP/Torque are you at and what do you think is your goal.
I am trying to figure out what the magic number is to have the right balance between performance and drivability/relability
Old Dec 6, 2009 | 09:56 AM
SteveG75's Avatar
SteveG75
I am probably right about 375 HP/400 ft lbs at the crank. Like to get it in the 550 range for both at the crank.
Old Dec 6, 2009 | 10:05 AM
rellim51's Avatar
rellim51
Could you tell a difference when you went from the 2101 to the 7101?
Old Dec 20, 2009 | 03:52 PM
rbat's Avatar
rbat
change of plans though, I am considering going with typhoon manifold (pc-2020 from skip white performance) and holley 750DP "if" it will fit.
thanks again
Old Dec 20, 2009 | 04:30 PM
'75's Avatar
'75
Here are directions for posting pictures. http://forums.corvetteforum.com/help...al-inside.html
To hood clearance question
Old Dec 21, 2009 | 01:47 AM
rbat's Avatar
rbat
Default thanks for the help!
here is my hood, do you think the typhoon manifold will fit using the holley 750 DP? Can you tell which hood I have??
Old Dec 21, 2009 | 11:13 AM
rbat's Avatar
rbat
ttt
Old Dec 21, 2009 | 09:04 PM
'75's Avatar
'75
That looks like a stock 75 hood.
