Where is rear toe measured?
Old Dec 5, 2009 | 04:52 PM
bronzebb's Avatar
bronzebb
Default Where is rear toe measured?
Is it at the outside diameter of the tire at the horizontal centerline? Or somewhere else? I understand geometry just where is it measured?
Thanks,
TT
Old Dec 5, 2009 | 06:47 PM
Jeff78's Avatar
Jeff78
It does not matter at wht height you measure toe just so that you measure at the same height front and rear of the tires.
Old Dec 6, 2009 | 01:34 PM
BenUK's Avatar
BenUK
Thanks,
TT
According to the AIM for my '76, you measure at the outer diameter of the tyres:
X - Y should = 3/32" per side
Old Dec 6, 2009 | 01:44 PM
Mike Ward's Avatar
Mike Ward
Ben is correct. If a setting is mentioned in inches, then the spot where the measurement is taken is important. If it is mentioned in degrees (angle) then it doesn't matter where it's measured from. Interesting that the factory specs have one of each.
Old Dec 6, 2009 | 03:12 PM
Golden's Avatar
Golden
If you give me the overall (wheel+tyre) diameter of the wheel I can tell you what 3/32's are in degrees/minutes.
Old Dec 6, 2009 | 10:37 PM
bronzebb's Avatar
bronzebb
It is clearly shown in my 1968 AIM on page B5.It is OD of tire. Should have checked.
Old Dec 6, 2009 | 11:01 PM
BenUK's Avatar
BenUK
You're welcome.
Old Dec 7, 2009 | 01:05 AM
bronzebb's Avatar
bronzebb
Thanks Ben
To Where is rear toe measured?
