Suspension
Old Dec 6, 2009 | 01:35 AM
jordan89's Avatar
jordan89
Default Suspension
How can I tell what suspension I have(regular, F41, Gymkhana)? Is there a specific measurement to any suspension component? The fuel tank was replaced by the previous owner, so the build sheet is no longer there. I would really like to know what I have.
Old Dec 6, 2009 | 03:06 AM
Highhat's Avatar
Highhat
I was told to measure the leaf thickness of one leaf:
1/4" thick - 7-leaf
5/16" thick - 5 leaf Daytona
Old Dec 6, 2009 | 04:46 AM
hunt4cleanair's Avatar
hunt4cleanair
It's helpful to know the model year. Shock numbers, if original can offer a clue and motor. If parts have been replaced, the best evidence may be what the previous poster suggested, leaf spring width and number of leafs.
Old Dec 6, 2009 | 06:20 AM
Duke94's Avatar
Duke94
Gymkhana should have a rear sway bar with 1.25" front sway bar as well as the spring mentioned by the other posters.
Gary
Old Dec 6, 2009 | 07:56 AM
jb78L-82's Avatar
jb78L-82
Gary
The size of the sway bars varies depending on the year with the 78-80's having the biggest combination of front and rear bars. The earlier years had a smaller front bar but I believe all of the gymkhana suspended cars had a 7/16th inch rear bar. All gymkhana/F-41 cars had a rear bar thus the easiet way to identify one is to just peak through the rear wheel opening to look for a rear bar with an OEM vertical endlink, not a horizontal endlink (like the front bar) which indicates an aftermarket rear bar. Also, as noted above, the F-41 cars have a 7 leaf rear spring versus a 9 leaf base car spring, if they still have a steel rear spring. Finally, my 78 came with a 1 1/8 inch front bar. The F-41 cars did not have a 1 1/4 inch front bar. Hope that this helps!
Old Dec 6, 2009 | 08:58 AM
Duke94's Avatar
Duke94
Correction, I looked in my "Corvette restoration guide" and it says all 73-74 Big Blocks got the rear sway bar as well as those equiped with FE7 or Z07 suspension. So just having the rear bar is not the tip off for FE7 unless you have a small block. It also says all 73-74 rear bars are 9/16" dia.
Gary
Old Dec 6, 2009 | 11:53 AM
jb78L-82's Avatar
jb78L-82
Gary
You are absolutely correct about all big blocks having the rear sway bar!-I was referring to the small block cars which I failed to mention-Sorry about that since it irritates the crap out of me when others give the wrong "advice". Thanx for the correction/clarification.
Any small block car from mid to late 70's that has an OEM rear bar is a gymkhana suspended car. Also, my 78 I believe did not have a 9/16th rear bar since I remember when I purchased the nylon replacement sway bar mounting bushings and installed them, the rear bar was VERY small, definitely not more than 1/2 inch which is why I referenced the 7/16th rear bar. I currently run an OEM type 3/4 inch rear bar with the stock 1 1/8th inch front bar with poly end link AND mounting bushings. Hope that is clearer.
From Wilcox's website:
42670 1963-1982 Rear Sway Bar Bushings. Polyurethane 7/16 Inch 63-82 $33.99
Old Dec 6, 2009 | 02:28 PM
jordan89's Avatar
jordan89
Forgot to add, it's a 74 L82 and all original. I'm going to check the shocks to see if they are original.
Old Dec 6, 2009 | 02:37 PM
jb78L-82's Avatar
jb78L-82
Does it have a rear sway bar and/or a 7 leaf rear spring? I doubt the shocks are original.
Old Dec 6, 2009 | 03:36 PM
jordan89's Avatar
jordan89
Well there's no sway bar in the rear, so that will rule out an F41 suspension .
Old Dec 7, 2009 | 04:52 AM
hunt4cleanair
And in 74, FE7 did not include the rear sway bar. How many leafs in the spring?
Old Dec 7, 2009 | 05:01 AM
cottoneg's Avatar
cottoneg
If it is not an F-41, then the difference between a stock spring and Daytona is night an day. I had a DAytona suspension. The springs are thick and the fronts are 860 pound springs. I forget stock, but is was something like 280.
Push on the car, if it moves, you have the stock spring. If the spring is really thick and all that flexs is the sidewall of your tire, you may have a DAytona.
Old Dec 7, 2009 | 07:14 AM
jb78L-82's Avatar
jb78L-82
Do you know for a fact that the 74 FE-7 did NOT have a rear bar? I am not sure about the earlier 70's SB cars not having a rear sway bar with the sport suspension, thus my question, and my comment above, about only the mid to late 70's C3's having the rear bar. Just trying to confirm although my friend who had a 74 L-82 in college did not have a rear bar either but I do not know if it had the sport suspension.
Old Dec 7, 2009 | 07:14 PM
jordan89's Avatar
jordan89
I'll have to check the leaf spring tomorrow. The weather is ugly out here right now and the car is outside.
Old Dec 7, 2009 | 11:46 PM
flynhi's Avatar
flynhi
Sway bar articles
http://www.northtexasamc.com/pdf/HMM_Anti_Roll_Bars.pdf
ANTI-ROLL BAR RATES
The only job of the anti-roll bar is to handle roll resistance. We can determine the roll rate of an anti-roll bar through the mathematical formula:
R = [(pi)(G)(d^4)] / [(16)(b^2)(L)
where R is the roll rate in pounds per inch, pi is 3.14, G is the modulus of the material; d is the diameter of the bar; b is the length of of the roll bar arm measured from center to center; and L is the length of the anti-roll bar.
As we can see, the diameter of the bar has the greatest effect. Small changes in bar diameter result in large changes in anti-roll bar rate since it varies as the fourth power.
Plug and Chug Bar calculator
http://users.erols.com/dmapes/SWBRCLC.HTM
Formula and Diagram
http://lumenique.com/Cars/mcoupe/mod...tirollbars.htm
Old Dec 9, 2009 | 03:21 AM
hunt4cleanair
Yeah...just about 100 percent. I've researched and have documented the FE7 suspension system from 74 through 82. The 74 front bar was not as thick as the 75-82 bar...In fact it was the same bar as used for the F41 suspension in early 70's.
To Suspension
