Speedo needle bouncing
Old Dec 10, 2009 | 08:00 PM
Surfer69's Avatar
Surfer69
Default Speedo needle bouncing
When the muffler shop installed my new system they forgot to lift the speedo cable off the pipes. It melted and seized up. So I replaced with a new one but didnt replace the gear in the tranny.
Now at highway speeds the needle sways back and forth around 4-6 mph never staying still. At lower speeds I guess it's not noticeable.
Anyone seen this before and could it be my plastic gear or something else?
Old Dec 11, 2009 | 10:57 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
the cable maybe too long , or has a bad twist in it , look at it and see the routing , if you have a sharp turn it may make it jump , I find the replacement cables are junk! Ron
Old Dec 11, 2009 | 12:02 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Make sure the cable is well lubed
Old Dec 11, 2009 | 02:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Bingo.
Old Dec 11, 2009 | 04:07 PM
Surfer69's Avatar
Surfer69
How do you make sure it's lubed? Use grease or motor oil?
I don't recall noticing any kind of lube.
Old Dec 11, 2009 | 06:23 PM
AzMotorhead
use a low temp grease on it. A light coating of white lithium grease should do it
Old Dec 11, 2009 | 08:57 PM
CCrane65's Avatar
CCrane65
Use graphite. It's not affected by cold temperatures. It's also a dry lube so it won't gum up over time. It's powdery so take the cable out of the jacket and put the graphite on a rag, grab the rag from the bottom, wrap your hand with the rag around the cable and pull the cable through it.
If your speedometer cable can't be removed you will need to pour or inject the graphite into the end. Much tougher to tell if you got the whole thing that way.
cc
Old Dec 12, 2009 | 08:20 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
cc
Corvette Speedo and Tach Cable Lubrication Instructions AC Delco
http://willcoxcorvette.com/repairand...lp.php?hID=283
Old Dec 13, 2009 | 01:35 AM
TimAT's Avatar
TimAT
I had that same problem on my 77. New cable didn't help. Pulled the speedo and took it to a local shop- he ran it on his test machine- same thing- the bearings for the needle were bad. $125 later and it's new.
Old Dec 13, 2009 | 10:09 AM
0Willcox Corvette
Former Vendor
Tim I'm with you on this and in most cases the head is the problem. I was under the impression the problem didn't start until the original cable was burned. It may just be the first worm and magnet bushing that is causing the problem.
Might also be a cable in a bind, or lack of lubricant on the cable. One quick way to find out is to remove the cable from the tranny, make sure it's not in a bind and then run the speedo up with a drill.
Willcox
To Speedo needle bouncing
