650 or 750
Old Dec 10, 2009 | 10:35 PM
Sweet's Avatar
Sweet
Default 650 or 750
I have a new 420 HP 383 crate motor with a 6000-rpm red line.
The builder says to run a 750 double pumper.
The Holley Tech says all a 383ci needs is a 650 double pumper. He said that the 750 will hurt bottom end and only help above 6500-rpm.
What do you guys think.
Old Dec 10, 2009 | 10:47 PM
c3corvette77's Avatar
c3corvette77
run the 750. it will not hurt the bottom end and might even pick up a few ponies on top. your real issue is vacuum vs mechanical secondaries. if you're running an automatic trans, go vacuum no matter what. i speak from experience. you will need a tall converter and a lot of gear, like 3.73s to make the mechanical secondaries happy. i have a 750 DP holley on my car and i don't have enough converter stall or gear to make it happy off the line. i want to put a manual in the car so i'm living with it till then. if i was staying automatic, i'd swap to vacuum secondaries.
Old Dec 10, 2009 | 10:53 PM
cherrybombc3's Avatar
cherrybombc3
Alot of guys like to over carb thier engine thinking bigger is better. I went through this on my 383 (dyno @ 460 crank HP w/ a 750) I ran a 750 Holley HP on it and it roared but was not happy with the low end, right off the top of the pedal. I did have it dyno tuned & it was tweaked. The dyno tech suggested it may pull more velocity with a 650, so I called the Holley tech and he agreed. OK, so I mounted a 650 Holley and viola, just the responsivness I was looking for, pulls hard all the way through the pedal & off the line it's a screamer! I know it has alot to do with your particular set up & your heads. Bring more air in, you must be able to get more air out. This of coaurse is only indicitive to my set up but just dont be eager to over carb.
Old Dec 10, 2009 | 10:54 PM
OzzyTom's Avatar
OzzyTom
IMHO...
First off I say stick with a 750cfm carb on a 383 with a 6000rpm redline. You will achieve better peak power from your engine.
Sure a 650cfm might provide a bit more torque down low, but if you want performance, its power in upper range that counts.
A 650 cfm will begin to choke at upper rpm and cost you peak horsepower.
However....
Are you running an auto? or a manual trans?
If using an auto, you may be better off with a vac secondary 750.
The transition to secondary venturis is smoother and works better with slush box.
cheers
tom
Les's Avatar
Les
Without hesitation I'd go with the 750. You have plenty of cubes & power to utilize that carb. I doubt you'd lose much if any low end at all and you'll pick up at the top end. On a mild 350 the 650 would definitely be the right choice. Another Holley tech would have told you to use the 750- not all those guys are blessed with real world experience. Good luck & enjoy your new motor!
Old Dec 10, 2009 | 11:04 PM
c3corvette77
another problem we face is these cars are heavy, mechanical secondaries like lighter cars too.
Old Dec 10, 2009 | 11:05 PM
Sweet's Avatar
Sweet
I have a manual trans. and I'm running the motor with a 670, vacuum secondaries. The engine has an off idle stumble. I was told that due to cam I have low engine vacuum. The engine builder and Holley Tech said I need a double pumper to get rid of the stumble. But they do not agree on the size.
Old Dec 10, 2009 | 11:10 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Old Dec 10, 2009 | 11:12 PM
10caipirinhas's Avatar
10caipirinhas
Use a vacuum secondary 770 or 780.........
Old Dec 10, 2009 | 11:23 PM
c3corvette77
off idle stumbles generally point to accelerator pump shot. usually it's a sign of not enough pump shot and you should try a larger accelerator pump squirter, 3 sizes bigger than what you have now. however, it can also mean you have too much pump shot already. only way to know is to try different tune ups. holley has a tuning guide on their website you can download. tells ypu how to set the accelerator pump actuating rods and such. pretty informative.
Old Dec 11, 2009 | 11:01 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old Dec 11, 2009 | 11:17 AM
FRSTR90's Avatar
FRSTR90
You might have to use your seat of the pants dyno.. I would say that about 4000-4500 RPM's you'll notice a huge difference between the 750 and the 650. When I was testing carbs on my my L82 with a slightly larger than stock cam, sure, the 650 had a little more snap, but by 3000 rpms the difference was hardly unnoticable. By 4000, it felt like the 650 was starting to run out of breath and the 750 definitely had more pull up top. I probably would only consider a 650 carb, if I was building a 350 with a redline of 5500-6000. The 383 will appreciate the extra flow.
Old Dec 11, 2009 | 11:31 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default 650 double pumper
I have been using a Holley 650 double pumper on my original owner 1970 Corvete 350 turbo 400 since 1974. It has 3:08. I love having absolute full control of the manual secondaries, I would never consider having anything but the double pumper manual secondaries.
My original owner 68 327/350 4-speed 3:70 has had the same type Holley 650 double pumper since 1974, no way would I change from the mechanical control of the secondaries.
Having no mechanical control of the secondaries during the early use of my 68 and 70 was enough for me. Instant starts, with the Holley's.
My operating rpm use does not usually go above 5K, no race track use, just good ole enjoyable driving all these years.
Old Dec 11, 2009 | 12:03 PM
billla's Avatar
billla
St. Jude Donor '14
The smaller carb isn't going to give up any power with those CID/HP numbers, and will provide better throttle response in all scenarios except zero-to-WOT.
I agree that I'd tune what you have before buying something new. A DP carb can cover bad tuning by just pouring gas into the engine - but that's not good for the engine or for your wallet.
Old Dec 11, 2009 | 12:06 PM
midyearvette's Avatar
midyearvette
Old Dec 11, 2009 | 07:05 PM
marz's Avatar
marz
Who built the motor and if it was an engine builder what does he say? Mine was a crate motor and dynoed at the plant and all of the documentation they gave me and advice was to go with a 750 double pumper for the most torque and hp. I thought I knew better and fooled around with a couple of smaller carbs, but in the end I have a BG 750 Speed Demon. Like someone said earlier...take it out and you be the judge by stomping on it with both carbs.
Pics?
Old Dec 11, 2009 | 10:08 PM
OMF's Avatar
OMF
The real issue that has not been addressed is what kind of driving are you really going to do with this car? If its mostly street driving with the odd spirited blast I'd choose the 650. If it's mostly drag strip/autocross/beating on it all the time I'd choose the 750.
The 650 will take your engine right to 7000 rpm no problem....it just won't make the peak power that the 750 will.....guessing at 15-20 HP less.
To 650 or 750
Old Dec 12, 2009 | 09:42 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I have a 383 stroker with approximately 450 hp in my 61. I put a Speed Demon 650 double pump on it. Great throttle response and low and mid range torque. Could it use a 750? Well, if I lived frequently over 6500 RPM's, which I don't, I suppose so. The 650 is plenty of carb for the way I drive. If you are going to race your car or are constantly hammering it at higher RPM's then go with the larger carb.
Old Dec 12, 2009 | 10:04 AM
Golden's Avatar
Golden
If I've done my maths correctly at 6000rpm a 383 requires 663 CFM.
If the engine is staying as is, I would definitely go for the 650.
Although theoretically it might fractionally strangle the engine at max rpm, depending on the cam you may be dropping off the power curve anyway.
For the potential tiny loss at max rpm the throttle response, smoothness and torque will more than make up for it. How often do you drive at max RPM? You don't, you hit it and change gear.
If you have further plans for the engine, different cam, higher rev limit etc then you should go for the 750 to allow extra flow.
The Holley guy is right, the 650 is the best match for your engine.
Old Dec 12, 2009 | 11:45 AM
billla's Avatar
billla
St. Jude Donor '14
The good "rule of thumb" formula is: CFM = ((CI x RPM)/3456) x VE
I see VE as right around 85% for an engine making around 1 HP/CID.
So the engine overruns the 650 at around 7000 RPM, the 750 around 8000 RPM.
On a 650, we're into the secondaries at around 3500 RPM.
I'll stand by my comment that tuning the existing 670 is likely to produce the best overall results - even if it does give up 2-5 ponies peak HP.
