trailing arm question
Old Mar 1, 2002 | 11:54 PM
jvm's Avatar
jvm
Default trailing arm question
I got them redone at Bairs. and have a prothane poly kit . But on the back connection of the arms that uses a 3 1/2 bolt there are bushings Prothane calls them end link set. It bolts to the 7 leaf spring The kit ones don't seem to be large enough in diameter. I didn't pay attention to them before I sent them off to Bairs. They didn't come back with any thing on the T/As. Any one done this before??? Thanks Jim
Old Mar 2, 2002 | 01:24 AM
R. Bruno's Avatar
R. Bruno
Default Re: trailing arm question (jvm)
Where are these bushings exactly? Do they go on the trailing arms?
Old Mar 2, 2002 | 06:57 PM
jvm's Avatar
jvm
Default Re: trailing arm question (R. Bruno)
The are toward the rear of the T/A and use a 3 1/2 bolt to atteach to the 7 leaf spring. There are bushings that go through the arms to the spring.
Old Mar 2, 2002 | 07:11 PM
Brutus's Avatar
Brutus
You may find that the end link set of bushings belong to the sway bar and not the spring mounts that you are thinking of. The spring bushes are 2" in diameter and the sway bar ones are 1". Hope this helps.
Old Mar 2, 2002 | 07:53 PM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
a photo would help :yesnod:
Old Mar 2, 2002 | 11:11 PM
R. Bruno's Avatar
R. Bruno
My TA's are on the way back from Bairs. I think I know the bushing you are talking about though. If I recall there is a bushing in the trailing arm where the spring bolts slide through. Didn't they put all new bushings in the arm?
Old Mar 2, 2002 | 11:34 PM
Juliet's Avatar
Juliet
Default Re: trailing arm question (StrayDog)
I don't know if this will help, but here are some of my 'BEFORE' pictures from my rear suspension overhaul. (ie, I know they're nasty rusty looking - but it's all out of the car being restored as we speak). :jester
Old Mar 2, 2002 | 11:45 PM
R. Bruno's Avatar
R. Bruno
Default Re: trailing arm question (Juliet)
Thanks Juliet. That picture is helpful. I was thinking there was an additional bushing in the rear of the trailing arm where the spring bolt goes through but the only bushings I see are the large bushing on the bolt itself. My arms are out also. Just put the diff. back in today and got word last week that my arms and halfshafts are on the way. JVM- does this picture help?
Old Mar 4, 2002 | 11:08 AM
jvm's Avatar
jvm
Bruno Thanks for the pic, yes it does help. Think I can put the piece back together again. sort like humpy dumpty. Hope I don't end up with some left over. Jim
To trailing arm question
