Wiper motor/relay solution '78 PC
Old Dec 12, 2009 | 09:27 AM
leetownreb's Avatar
leetownreb
Default Wiper motor/relay solution '78 PC
I disconnected the relay, wired another hot to the motor directly, and got my wipers back!! Only 2 speeds, but I'm happy w/that. I had wired in another switch to bypass; now I don't need it. I think the metal around the original fuse was corroded and needed another 12-V tap. This seems to be a common thread (pun intended) on the forum. At least the motor works off the original switch.
