Help With Temperature Cable
Old Dec 14, 2009 | 09:40 AM
Stanthehandyman's Avatar
Stanthehandyman
Default Help With Temperature Cable
My vet is an 81 and I have a question about the temperature selector cable that connects to the ac/heater control assembly on the center console. It is just hanging loose and I can see how it slides into the control assembly (at about 90 degress) but I do not see how it stays locked in that position. Is there a clip, screw or other type of connector that holds it in place? I do not have a new unit to look at so I don't know if the cable is bad or also the control assembly. Many thanks for your help.
Old Dec 14, 2009 | 09:50 AM
...Roger...'s Avatar
...Roger...
Here is a thread where it was being discussed with pics and a repair I believe.
http://forums.corvetteforum.com/c3-t...rol-panel.html
Old Dec 15, 2009 | 09:18 AM
Stanthehandyman
Wonderful and many thanks for the help and I wired it up temporarily now and will look for the proper connector but it works and it is holding.
To Help With Temperature Cable
