Valve train experts
Old Dec 14, 2009 | 04:15 PM
Gordonm's Avatar
Gordonm
Default Valve train experts
I just got my new heads and roller cam. Mocking it up my pushrod checker says I need to go .050 longer on the pushrods. They are already .150 longer than stock. Here are 4 pictures of how the rocker is rolling across the valve tip. It does not look to bad but a slightly longer pushrod would put it a little further out on the stem. Do you want it where it is or further out on the stem?
Old Dec 14, 2009 | 04:23 PM
gkull's Avatar
gkull
I would say that you are splitting hairs. What happened to me is I went with .200 or .250 over and I ended up having to get the longer ARP rocker studs to have enough thread for the rocker locking nuts.
I would invest in a set of 16 lash caps for that valve stem size and call it good.
Oh ya, nice clear pictures!
Old Dec 14, 2009 | 04:28 PM
Gordonm's Avatar
Gordonm
If I put on the lash caps won't that change the pattern on the valve stem ie raise the valve height a little more?
Old Dec 14, 2009 | 04:50 PM
gkull's Avatar
gkull
Lash caps would raise the stem height, but they give the roller tip more area to push on. So you get less guide side thrust and saves the valve stem tip with big roller cams.
Just a tid bit of information. As your spring diameter gets to be near 1.55 diameter you can't get even get a thin wall socket on the head bolts between the springs.
Save yourself some aggravation and just go buy the ARP 12 point head stud kit and a deep 12 point socket that fits on them.
Old Dec 14, 2009 | 04:59 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I agree with 12 point solution. The pattern is fine, I don't even bother doing that I just use my eye and crank it over and watch the roller go across the tip. This of course should be done with motor out so you can see what is going on
Old Dec 14, 2009 | 05:09 PM
midyearvette's Avatar
midyearvette
run that puppy.....stems look great.....good luck
Old Dec 14, 2009 | 08:40 PM
C3 Stroker's Avatar
C3 Stroker
......looks right where you want them to be.
Old Dec 14, 2009 | 10:51 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Does the sweep get any narrower with shorter pushrods?
JIM
Old Dec 15, 2009 | 01:03 AM
Solid LT1's Avatar
Solid LT1
Fine to be a little closer to rocker pivot, than further outboard. Looks good to me.
Old Dec 15, 2009 | 06:40 AM
Gordonm's Avatar
Gordonm
I talked to AFR yesterday about lash caps. They are like buying cheap insurance. He was saying most that run solid rollers it is recomended but not necessary. Choice is up to me. It does provide a bigger area for the contact point and less chance of the valve tip mushrooming over. So for the 35 bucks or so I bought a set. I'll probably now need a new set of pushrods but I'll check it again when the caps arrive.
Old Dec 15, 2009 | 07:06 AM
midyearvette
do you have room for them??
Old Dec 15, 2009 | 07:52 AM
Belgian1979vette's Avatar
Belgian1979vette
Don't want to hi-jack the thread, but about those lash caps. I have those, but I don't seem to be able to get them on the valve, since the though the keepers...Any idea's ?
Old Dec 15, 2009 | 07:57 AM
midyearvette
i dont understand your post with the typo, but you want to be sure you have clearance from the bottom of the cap to the keepers and retainers...they are really used to protect the stem from excessive lash pounding and godzilla spring pressures and rocker geometry should be re checked when using them...usually requires a different length pushrod...jmo....
Old Dec 15, 2009 | 08:11 AM
gkull's Avatar
gkull
The word is "touch"
Not all keepers are created equal. You have cheap stamped, hardened, and machined.........7 degree and 10 degree.
If you don't have space you can't use them.
Old Dec 15, 2009 | 10:53 AM
Gordonm's Avatar
Gordonm
The keepers I ordered are right from AFR. I asked if they would fit and they assured me they are for the newer style 8mm valves and they would fit. I will post a picture when they arrive and are on the head. I asked about the pushrods and he said I might need new longer ones. They are .080 thick so I assume new ones will be needed.
Old Dec 15, 2009 | 11:09 AM
gkull's Avatar
gkull
I would tend to believe that they are .080 from top to bottom, but they are shaped like a cup. So the top might only add .040 or less to the stem height.
Smarter people epoxy magnets near the oil return holes or screen the oil returns. This summer a brand new engine broke some rocker arms and a lash cap ended up luckily in the bottom of the oil pan. We have since retrofitted every American V-8 with magnets
Old Dec 15, 2009 | 11:53 AM
GOSFAST's Avatar
GOSFAST
Default Lash Cap Dimensions
Pictured below are both the "standard" lash caps and the "shallow" ones.
These are Comp's "standard's" and Crower's "shallow's"!
Both are identical from the very top to the inside valve stem area, .080" thick!
The "standard's" are .210" tall from the topside to the bottom of the wall section, the "shallow's" are .145" tall from the topside to the bottom wall section!
Thanks, Gary in N.Y.
P.S. When using ANY lash-caps you must make certain that there's a "gap" between the lash cap itself and the valve locks, they must not make contact with the locks at all!
To Valve train experts
Old Dec 15, 2009 | 12:29 PM
gkull's Avatar
gkull
Good to know. I never micrometered one. They just seem small. So I would say that the ones I have messed with must be the shallow version.
Old Dec 16, 2009 | 07:42 PM
morganjd's Avatar
morganjd
I just installed lash caps on my LS6 and needed to go with longer push rods. My brother in law works for trend industries here in michigan, they make all of the comp and trick flow push rods, along with others. They engrave whatever name the customer wants on them. just google trend industries, they also own diamond pistons and make all of the harley davidson push rods and hendrick motorsports lifters (they are a work of art). I think they are cheaper than buying them from comp and have all the sizes you would ever need IN STOCK. If you are in michigan, you can walk right in and take them home. The only other ones to buy are from smith brothers
Old Dec 16, 2009 | 08:04 PM
Gordonm's Avatar
Gordonm
No luck with Googling them. Do they have a website?
