Another question about 18s
Old Jan 1, 2010 | 12:14 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by kellyr073
Are you guys all running stock Trailing arms with the 5" backspace on 9.5 wheels? I am in the process of intsalling offset TA's.
You shouldn't need offset TA's with 18's and a 5" BS.
Old Jan 1, 2010 | 12:11 PM
Billysvette's Avatar
Billysvette
Originally Posted by Southcp
Hi Billy, What brand tires and size do you have on those rims? Also do you have stock trailing arms or offset ones. I have a 71 Bridgehampton blue 454 that those tires and rims will look awesome on.
They are falken tires and they are the stock height as original wheels.
Rear tire size is 275-40-18 and the front is 255-45-18.No offset trailing arems ,you dont need themwheels and tires fit perfect under car.One small note though,i used 3/8 spacer on the front because i thought the wheel was a little too far inward.spacer was cheap.rims were 18x8 front and 18x9.5 rear
Old Jan 1, 2010 | 01:52 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Mine are stock trailing arms with 9.5 inch wheels and 5 inch bs with Toyo T1R 285/40/18's
Old Jan 1, 2010 | 02:17 PM
Bee Jay's Avatar
Bee Jay
I ran 275/40-18 tires on 9.5x 18 wheels for a couple of years with stock trailing arms, 2.5" adapters, no problems. After installing offset trailing arms and triming the frame a little, I now run 295/35-18 tires on 10.5x 18 wheels, with 2" adapters. After triming the frame, I have room I believe for 305 or 315 tires. I won't find out untill I wear these 295s out. Here is a link to my frame mods to fit the 295 and larger tires:
http://forums.corvetteforum.com/c3-t...clearance.html
Bee Jay
