Upper Radiator Hose
Old Dec 19, 2009 | 05:27 PM
autoist's Avatar
autoist
Default Upper Radiator Hose
I have a '77 with an '86 TPI engine......have the '77 radiator....neither the '79 nor the '86 upper hose fits.....& one of those ribbed hoses that can be bent into the shape needed hits the alternator pulley.
How did those of you who've done the conversion solve that problem?
Old Dec 19, 2009 | 05:44 PM
TPI BOY's Avatar
TPI BOY
Old Dec 19, 2009 | 06:19 PM
autoist's Avatar
autoist
Guess you have the same question, eh?
Old Dec 19, 2009 | 07:01 PM
72LS1Vette's Avatar
72LS1Vette
Are you talking about a rubber ribbed hose or a metal one? The metal ones should be able to be bent to fit and since they are more rigid than the rubber ones they shouldn't move once you bend them into shape.
Rick B.
Old Dec 19, 2009 | 08:34 PM
TPI BOY's Avatar
TPI BOY
I used a 10degree angled water neck, 360 degree ajustable.
Aso used the metel hose you can buy at summitt or jegs
Old Dec 19, 2009 | 08:52 PM
autoist's Avatar
autoist
I was using a rubber ribbed hose...don't know about metal adjustble hoses!!
& are you saying I need to replace me OE thermostat cover wth one that's angled? Where does one get such a thing?
Oh, any photos?
Old Dec 19, 2009 | 09:01 PM
TPI BOY's Avatar
TPI BOY
Oh, any photos?
I bought mine at Street Performance online http://www.hotrodlane.cc/ What type of Tpi
do you have is it maf or speed density, mine is speed density
Old Dec 19, 2009 | 09:05 PM
72LS1Vette's Avatar
72LS1Vette
Something like this:
http://www.summitracing.com/parts/MRG-11010C/
You can bend them any way that works for you.
Rick B.
Old Dec 19, 2009 | 09:12 PM
TPI BOY's Avatar
TPI BOY
Rick B.
Yes, that's it
Old Dec 19, 2009 | 09:28 PM
autoist's Avatar
autoist
Here are a couple of photos....lots more done to it since then....I'll take some new photos & post them:
That metal pipe is what I need....thanks for the link.
Old Dec 19, 2009 | 09:51 PM
autoist's Avatar
autoist
As you can see, my car is still apart...but, I'm trying to solve all the problems before we put the body back on....oh, you can see the MAS sensor in the 2nd photo....it's the green plug.
Old Dec 19, 2009 | 11:38 PM
forvicjr's Avatar
forvicjr
Middle 90,s 4.3 waterneck,(s-10) willroute hose bhind alt. I had to cut mine a little to work but its not a bubba fix. Then find yourself a long upper hose with a 90 degree bend to go from rad to right of alt and 90 bend left behind alt to modified neck.. m2cents
72 ls1vettes idea is prettier than my idea though!! Guess im a budget builder and use what i can..
Old Dec 20, 2009 | 05:56 PM
autoist's Avatar
autoist
Do you have a photo of that setup w/hose behind alternator? I'd thought of that but couldn't visualize.....
Old Dec 21, 2009 | 03:45 PM
forvicjr's Avatar
forvicjr
Dont have a photo, done this to a tpi motor in a s-10 had no room for hose to connect as the tpi neck was set up. my alt was a little closer to being in front of the valve cover. but looks to me that this solution will still work. go to gm site and look that water neck up. should have a photo of it. As i said this neck will send the upper hose out over the drivers valve cover right behind alt and 90 towards rad.
sorry for the slow response..
95-97 s-10 4-3 water neck..
Old Dec 21, 2009 | 07:27 PM
TPI BOY's Avatar
TPI BOY
Just get a water neck that you can turn to any
place and get the metal hose and then your done
also is that the stock belt set-up
Old Dec 21, 2009 | 07:57 PM
autoist's Avatar
autoist
I removed the air pump and added the fake pulley so the belt loops as original.
Old Dec 21, 2009 | 08:12 PM
forvicjr's Avatar
forvicjr
PM sent.
To Upper Radiator Hose
