Headlight Actuator
Old Dec 19, 2009 | 10:11 PM
79corvette's Avatar
79corvette
Default Headlight Actuator
Hey guys, I need some help. I am currently trying to replace the seals in my actuators but I am unable to remove the pivot pin receiver. I have tried the method shown in the picture from Corvette Magazine, but I am just tearing up the shaft with the pliers. I have also been using some penetrating oil on it. How can I get this thing off? Thanks for the help.
Old Dec 19, 2009 | 10:23 PM
Grumpy 427's Avatar
Grumpy 427
Man sorry to hear that. I did mine this summer, and they came off ok. Do you have a bigger pair of locking vise grips? You need a stronger set of jaws to hold the shaft. Try soaking it in penetrating fluid over night. Not sure what else to tell you.
Old Dec 19, 2009 | 11:03 PM
...Roger...'s Avatar
...Roger...
Heat will take it off in a jiffy.
Take the bushing out first.
Old Dec 19, 2009 | 11:10 PM
Mike Ward's Avatar
Mike Ward
Never thought of that. Are they easy to get out and reusable?
Old Dec 19, 2009 | 11:13 PM
forvicjr's Avatar
forvicjr
Heat the threads and clevis and stick a candle to the hot threads. The heat will draw the wax into the threads loosening the shaft/clevis..
Old Dec 19, 2009 | 11:19 PM
...Roger...
They usually just slide out and most of the time you can use them again. If not they're only 2 bucks. http://ecklers.com/product.asp?pf_id=A6637&dept_id=1475
Old Dec 19, 2009 | 11:21 PM
...Roger...
I need to try the candle thing but always seem to forget.
Old Dec 20, 2009 | 12:39 AM
79corvette's Avatar
79corvette
Thanks for the responses. Tonight I will soak it in some more penetrating oil and try again in the morning. If that doesn't work I will try heating it.
I just have a stupid question, how hot do I need to get it? I'm not sure what I have around the house to heat it up.
Old Dec 20, 2009 | 01:04 AM
CCrane65's Avatar
CCrane65
Go to the hardware store and buy a BernzOmatic torch. They are really inexpensive.
cc
Old Dec 22, 2009 | 11:37 PM
79corvette's Avatar
79corvette
Thanks for the help. I tried letting it sit overnight with the penetrating oil and that did not work. Went to the hardware store on Monday and picked up the torch. It worked like a charm. Thanks a lot.
Old Dec 23, 2009 | 12:01 AM
...Roger...
Glad you got fixed. Noticed your in Naples, I'll be there in 8 days.
Old Dec 23, 2009 | 01:25 AM
kaiserbud's Avatar
kaiserbud
Mine was stuck last weekend and I broke it... I still had to remove a piece of teh shaft out of the eyelet part. And heat did it. But I heated it up and let it cool. Cycled it once or twice and I think that 'broke things loose' before I started tapping on it. When welding a new bolt to the end of the shaft, I kept the shaft cool with a water soaked towel - so the rubber seal did not deform.
Old Dec 24, 2009 | 02:00 PM
79corvette's Avatar
79corvette
Have fun in Naples. I just left the other day to visit my girlfriend for Christmas in Jacksonville and then heading out to Colorado for New Years.
That's a good idea. I was checking to make sure I didn't heat it up too much.
To Headlight Actuator
