Alternator lights!!! I'm going crazy
Old Dec 21, 2009 | 01:17 PM
pippo350's Avatar
pippo350
Default Alternator lights!!! I'm going crazy
Ok guys I'm doing some work on my vette and put a part the central consolle with the 5 cluster.
Today I have reassembled and everithink work fine but when the car is running the Alternator lights come up.
I have done some trial but it's still on.
In the same time the oil presure gauge go over 80 PSI,I have checked the connection on the switch and it's good,when I stop the engine the oil presure come backin the right place 30 PSI more or less.
The battery is ok I have tryed with and without battery charger connected in the battery but the result it's the same.
The voltmeter gauge show me 12/12.5 Volt and it's ok.
If I disconnect the alternator bulb everithing it's ok if I reconnect it the same think.
I'm just think some wires go to the ground.
This is my only think.
What happen about you?
Thank you Giuseppe
Old Dec 21, 2009 | 07:25 PM
wombvette's Avatar
wombvette
Thank you Giuseppe
I wouldn't expect the oil pressure to go over 80, probably not even near there unless you have some High performance set up. And, Zero would be the pressure of a stopped engine.
You should have about 13.5 volts with the engine running.
Old Dec 21, 2009 | 08:15 PM
mrvette's Avatar
mrvette
Giuseppe, I suspect from your english and name, that you are in Italy, and I feel it best to contact member PANIC is his handle/name, has a really heavily worked on Vette.....he can help you better due to talking heavy tech with translation problems....
wish I could be more help...but Merry Christmas, anyway....
Old Dec 22, 2009 | 06:26 AM
pippo350's Avatar
pippo350
Here I'm again,
mrvette you're right I'm Italian.
This morming I have fight with all cluster,now the situation is better than yesterday,the problem is the connection on the printed circuit,it is'nt to tight I push it and I have heard "click" this is the right position.Now everything works fine,the oil pressure at idle is 35,voltmeter show me 13.5.
The only think is when I put the keys on "on position" the alternator light don't work,maybe the bulb is burned,no drama I can check it by removing the glove box.
I'll check it later
Now I' m going to replace the old Hei distributor with a new one from MSD
Merry Christmas to all forum member !!!
To Alternator lights!!! I'm going crazy
