200-4R Transmission Lines
Old Dec 22, 2009 | 02:44 PM
autoist's Avatar
autoist
Default 200-4R Transmission Lines
I'm at the point of hooking my 200-4R transmission lines to the radiator & then on to the additional cooler in front of the rad.......I'm thinking about using flexible lines all the way.
However, I'm wondering if the hard lines for the 200-4R should be used and modified as needed to get to the additional cooler.
Anybody got opinions?
Anybody got photos of how their trans lines are routed?
Old Dec 22, 2009 | 03:08 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
on my 700r4 i used hard lines the entire way.....the last thing you want is for these to break you can use compression fittings if you need to splice into them
Old Dec 22, 2009 | 03:57 PM
forvicjr's Avatar
forvicjr
Go to napa they can custom make hydrolic lines for you. there good to 9000 PSI,any lenth and you can pick out the ends you want,straight 45 degree or 90 degree
Old Dec 22, 2009 | 04:56 PM
autoist's Avatar
autoist
That's basically my plan right now.....the store manager has been out to my shop a couple of times checking fittings & measuring lengths...he says go with flex....but, I'm not sure of routing as I'm using Hooker headers with side pipes.
To 200-4R Transmission Lines
