Jack Safety
Old Mar 3, 2002 | 10:16 AM
Paul L's Avatar
Paul L
Default Jack Safety
This from the local newspaper this morning. Another faulty jack or jacking method; another death. A Father with two children. Be careful when working on your cars!
http://www.canoe.ca/OttawaNews/15n1.html
Old Mar 3, 2002 | 12:28 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: Jack Safety (paul79)
This cannot be stressed enough-same way when working with gasoline or a torch around the cars. Always have a water hose pressured up or a fire-extinguisher!!! :yesnod:
Old Mar 3, 2002 | 12:53 PM
Red73's Avatar
Red73
Default Re: Jack Safety (Paul Borowski)
Paul, Great idea about the hose being turned on and up to pressure. The fire extinguisher is always with in reach but they don't last long. Rod
Old Mar 3, 2002 | 02:27 PM
mrvette's Avatar
mrvette
Florida is a huge sand bar, and as such has drainage/settling ponds in every development, someplace for the hurry-caine waters to go....
well this fellow who is reported to be a local car guy, hotrodder, works on his car, it gets away from him...rolls down his driveway, dragging him some 200' or so into the neighborhood pond...drowned...car still visible...
allways use wheel chocks, and stands....and I an guilty of not using stands upon occation, but never without chocks....sometimes just a floorjack for a quickey...but allways look and LISTEN....and check stability b-4 doing the dangerous.....
life may suck, from time to time, but shorter life sucks more.....
Old Mar 3, 2002 | 02:28 PM
Aaron76's Avatar
Aaron76
another good point is inspection of the jacks and stands
They could be cracked form the last time you used it and then all of a sudden they will give out.
I just bought a new 3.5 ton professional floor jack with a lock able coller now with 8 jack stands I can get it high enough to get the tranny out and still be safe.
Boy do I need a hoist.
Old Mar 3, 2002 | 10:30 PM
One GM A Tech's Avatar
One GM A Tech
Default Re: Jack Safety (Aaron76)
Actually I believe you can get somthing from northern tool or harborfreight for 400.00$ it will lift the front of the car or rear 36ins off the ground with saftey lock. Back on the subject saftey is always primary at the shop. And should be more so in the drive way never :nono: just jack a car and not use a stand This practice although commonplace is not and should not be the way. Nobody ever thinks that the 3400 pd car they are working on could suddenly and without warning could be resting on top of them crushing them quickly to the last daytona in the sky. It almost happenned to a bud of mine :eek: becareful my fellow vette owners. never get too comfortable because you do things over and over its a walk in the park, thats when the mistakes come with the short cuts And if that doesnt jar you think of those that you would leave behind that would be deprived at the loss anybody out there have kids? GET IT
Old Mar 3, 2002 | 11:15 PM
Paul L's Avatar
Paul L
Default Re: Jack Safety (One GM A Tech)
About five years ago I had my Corvette jacked up in the driveway to replace a power steering control valve. Left front. It was July and very hot. Had a jack stand under the front frame and a cinder block as well. Went to the basement to get a few tools and on my return the jack stand had toppled in the soft asphalt and the cinder block was crushed. I was shaken. That was a six-beer evening. Nuff said.
Old Mar 4, 2002 | 01:15 PM
john's '81 mouse's Avatar
john's '81 mouse
It's been said before, but worth repeating, never use, nor trust cinder blocks, they don't / won't work and can NOT be trusted. Use big block of wood or railroad tie, but not a cinder block. I always leave the jack under the car, in addition to the jack stands, plus, whenever possible, I use the wheel ramps, even more stable than the jack stands.
Old Mar 4, 2002 | 02:41 PM
Monkeywrench's Avatar
Monkeywrench
Default Re: Jack Safety (john's '81 mouse)
Persoanlly I'm scred to death of jack stands. I've had one collapse (fortunatley I was not under the car) and I've been very weary since then. Persoanly I like the idea of a KwickLift type device (http://www.kwiklift.com). Juts need to save up the pennies for one... :)
[Modified by Monkeywrench, 1:41 PM 3/4/2002]
Old Mar 4, 2002 | 03:18 PM
Edzred72's Avatar
Edzred72
I've seen enough industrial accedents to take every precaution available when working on the Vette. In addition to jackstands, I bought a 6' length of 8"x8" timber for around $20. I cut it into 15" lengths, stand them on end, and they fit nicely under the rotors. I cut them to 15" to hold the suspension up to almost ride hight. Longer would take the weight off the stands. (in my application) Please Paul... never use cinder blocks. I think you know that now!!
I've seen them crush under MUCH LESS weight than a car. :eek: :eek:
To Jack Safety
