Acceleration hesitation
Old Dec 24, 2009 | 03:10 PM
leetownreb's Avatar
leetownreb
Default Acceleration hesitation
Even when warm, there is a slight hesitation when I press the accelerator pedal (about .25") and then she flies!! Everything seems to check out. Any suggestions? I know there is a myriad of possibilities but maybe one of you has the secret. Thanx.
Old Dec 24, 2009 | 04:10 PM
WhiteC3's Avatar
WhiteC3
Accelerator pump working??? Not running take air filter cover off and have someone pump the gas pedal a time or two while you look down the primary carb barrels.If you see gas squirting your ok if not you need a accelerator pump.
Old Dec 24, 2009 | 04:53 PM
leetownreb's Avatar
leetownreb
there's an initial gas squirt as soon as the pedal is pushed
Old Dec 24, 2009 | 05:41 PM
WhiteC3's Avatar
WhiteC3
Sounds good. It could be power piston adjustment. But to find out the top of the carb will have to be pulled or power piston spring could be weak. I'm sure one of the carb gurus will chime in soon. You are running stock Q-jet right?
Old Dec 24, 2009 | 06:26 PM
corvettedave383's Avatar
corvettedave383
Ive had a slight hesitation before, for me its either been not enough initial squirt or too much, try a different coloured cam or different sized squirter
dave
Old Dec 24, 2009 | 09:23 PM
leetownreb's Avatar
leetownreb
Holley 600 cfm as far as I can tell. It's tuff when you buy a 30-year old car and the mods that were made are not passed on from one owner to another. Doesn't look too worn.
Old Dec 24, 2009 | 10:57 PM
mydejavooo's Avatar
mydejavooo
Could it also be a fuel pressure problem? I know from past experience that a tired fuel pump can also present problems like what you have described. Just a thought.
Trevor
Old Dec 25, 2009 | 12:42 AM
MN80Vette's Avatar
MN80Vette
I have a 600 cfm Holley and had the same problem. I increased the size of the squirters and switched to a bigger accelerator pump cam. I bought a set of them and picked the one with the earliest and longest lobe. That worked for me. I think I switched to the red cam. My '80 is on a lift with our son's '63 Nova under it, so I can't get to the engine to check for sure.
Make sure your acc pump is adjusted correctly also. I switched from the original acc pump arm to the arm from a 50cc kit. MUCH better.
Old Dec 25, 2009 | 01:53 AM
nitronick's Avatar
nitronick
Active Streak: 90 Days
Work the throttle through an entire stroke. There should be two solid streams into the primary barrels for the entire stroke.
Old Dec 25, 2009 | 01:11 PM
leetownreb's Avatar
leetownreb
Streams last momentarily. Where does one get the squirters, etc?
Old Dec 26, 2009 | 01:08 AM
MN80Vette's Avatar
MN80Vette
Holley accelerator pump nozzles (a.k.a. squirters) are available at most auto parts stores that carry Holley carbs. Find out what size you have now and get a pair 2 sizes up. Summit has a bunch of them:
http://www.summitracing.com/search/?...0nozzles&dds=1
If your accelerator pump arm is plastic, you should replace it with a metal arm. The plastic arms are known to wear and deform.
http://www.summitracing.com/parts/PRO-67237/
You might want to pick up some cams too:
http://www.summitracing.com/parts/HLY-20-12/
Old Dec 26, 2009 | 03:27 AM
73StreetRace's Avatar
73StreetRace
Did you check your timing ?
Are you using vacuum advance ?
When you press the gas pedal, the vacuum can should quickly remove vacuum advance.
If you have working squirters, I would check timing first.
Old Dec 26, 2009 | 10:26 AM
leetownreb's Avatar
leetownreb
Appreciate the feedback. Will check out recommendations.
Old Dec 26, 2009 | 10:59 AM
mds3013's Avatar
mds3013
If streams stop, that is most likely the prob. They should last like Nick said. That is where you should start. mds...
Old Dec 26, 2009 | 12:44 PM
SteveG75's Avatar
SteveG75
90% of percieved carb problems are really timing problems.
Old Dec 26, 2009 | 01:15 PM
MN80Vette's Avatar
MN80Vette
Check your timing first. That could save you the hassle of removing your carb. Changing to lighter springs in the distributor is easy. Make sure your dist weights move easily too.
Old Dec 26, 2009 | 01:28 PM
billla's Avatar
billla
St. Jude Donor '14
+3 (or 4) to look at timing. Timing, then carb.
To Acceleration hesitation
