Muncie trans ID
Old Mar 3, 2002 | 03:25 PM
467-Ratman's Avatar
467-Ratman
Default Muncie trans ID
Just pulled the trany out of my 71 coupe, like some help on info for the trany. I was told by the previous owner that it is a M-21, here are the numbers : GM 3851325 and on the back tube part the number is : 3846429.
Thanks in advance.
Old Mar 3, 2002 | 03:46 PM
Gordonm's Avatar
Gordonm
Default Re: Muncie trans ID (467-Ratman)
You will need the numbers that are stamped int oteh side of the case. These numbers you gave are just the casting numbers. Is the input shaft a 26 spine or 10 spline,
Old Mar 3, 2002 | 03:55 PM
467-Ratman's Avatar
467-Ratman
Default Re: Muncie trans ID (Gordonm)
Its a 26 spline shaft, Ill get the other numbers later. Thanks
Old Mar 3, 2002 | 04:01 PM
trw's Avatar
trw
Two ways to tell.
1) There will be either no groove around the input shaft splines or one or two grooves. No groove is a M-22, one groove is a M-21 (close ratio) or there are two grooves M-20 (wide ratio).
2) On the side of the case (passenger) there is a number that date codes the trans (it is stamped) it will end in either A, B or C. A M-20, B M-21 or C M-22.
Hope this helps
Terry
Old Mar 3, 2002 | 06:22 PM
467-Ratman's Avatar
467-Ratman
Default Re: Muncie trans ID (trw)
Here are the numbers from the other side. F179799 and 3831707 and on the front near the shaft GM 7 3851326. The input shaft has no groves.
Old Mar 3, 2002 | 08:04 PM
Gordonm's Avatar
Gordonm
Are you sure tha tis a Muncie. i checked those numbers and they don't seem to match up. The casting numbers don't look right. The number with the F in it is it stamped in or cast in. My 72 has a casting number on the case of 3925661 and the tail shaft casting is 3978764. I have a very early 72 so 71 should be similar. The number stamped into the case should start with a P. http://www.5speeds.com/ Try this website for the ID numbers and Muncie ID
Old Mar 3, 2002 | 08:25 PM
467-Ratman's Avatar
467-Ratman
The previous owner said that it was a muncie, but I have found many things he said to be not true. I do know that the car was an auto to start with and he converted it to a 4 speed. Sounds like I have some kind of GM trany, that most likely is not a Muncie!!
Old Mar 3, 2002 | 08:30 PM
Pete79L82's Avatar
Pete79L82
That is a Muncie. It is a 7/8" clustershaft model that was built prior to 1965.
With no grooves on the input shaft it should be an M-20 with a 2.56 first gear.
They didn't built M-22's until late 1966 model then popular in 1967.
[Modified by Pete79L82, 6:35 PM 3/3/2002]
Old Mar 3, 2002 | 08:42 PM
467-Ratman's Avatar
467-Ratman
Default Re: Muncie trans ID (Pete79L82)
Where can I go to get more info on this trany? Thanks for the help. :mad
Old Mar 3, 2002 | 08:43 PM
Gordonm's Avatar
Gordonm
But why would it be a fine spline. All Muncies built prior to 70 had the 10 spline coarse shaft. From 70 on they had 26 splines. the case numbers do look like early Muncie numbers. Are you sure it has 26 not 10 splines on the input
Old Mar 3, 2002 | 08:47 PM
redvetracr's Avatar
redvetracr
Tom,
Try this, http://www.gearzone.net/muncie2.htm
...redvetracr
[Modified by redvetracr, 6:53 PM 3/3/2002]
Old Mar 3, 2002 | 08:59 PM
Pete79L82's Avatar
Pete79L82
Default Re: Muncie trans ID (redvetracr)
The 1-2-3 groove identification that redvetracr refered to is correct for trans made after 1966. Prior to that there was only two identifications.
No rings = M-20
One ring = M-21
The stamping numbers don't seem to match anything that GM did. All there stampings started with a P designating a Muncie. GM did outsource Muncie trans to American Motors(Rambler back then) that were identical to the GM models. I am not sure how there stamping numbers went.
As redvetracr mentioned the casting number only indicate what the trans was originally. Measure the cluster shaft pin to see if it is 7/8" or 1". Someone may have rebored the cluster and replaces the input and clustershaft to something newer.
Old Mar 3, 2002 | 09:12 PM
467-Ratman's Avatar
467-Ratman
Dumb question, but is the input shaft the one that conects to the yoke then drive shaft or is the input shaft the one that goes to the clutch. Mine has 10 spine to the clutch and on the back of the trans its a 26 spline to the drive shaft.
Old Mar 3, 2002 | 09:25 PM
Pete79L82's Avatar
Pete79L82
Input shaft is the one that goes into the cluch disc. Output/mainshaft is the one the the driveshaft yoke slides onto.
With the 10 spline input/no rings/3851325 casting it looks like a pre 65 M-20.
Old Mar 3, 2002 | 09:35 PM
467-Ratman's Avatar
467-Ratman
Pete, Thanks for all of the help, once again my friends on the forum can figure out anything!
To Muncie trans ID
