Cold idle adjust?
Old Dec 27, 2009 | 10:28 AM
Attfay Elleybay's Avatar
Attfay Elleybay
Default Cold idle adjust?
Vette's idle is too high when cold (2500-3000). Is the screw at the center of the carb, under the butterfly flap the idle adjust? It's a Holley 4175 replacement for the Qjet.
Old Dec 27, 2009 | 11:07 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Look on the right side of the carb under the choke you will see this screw (the one that has the spring around it)
That is the fast idle adjustment you set it when choke is "On"
