Any speedometer-spezialists out there?
Old Dec 29, 2009 | 02:29 PM
Günther-C3's Avatar
Günther-C3
Default Any speedometer-spezialists out there?
Hello!
The miles-counter from my speedo doesn´t work, so I put it apart. Then I found an arm, which I don´t know for what it is.
Please look at the arrow at the picture. I can move him foreward and back. For what is it?
Thanks, Günther
Old Dec 29, 2009 | 07:34 PM
terry82's Avatar
terry82
http://www.harrisonspeedometer.com/see if they can help you .
Old Dec 29, 2009 | 07:48 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Here is what I had to do when my odometer froze up. I found it was the white numerals that was frozen. I freed them up and the speedo has worked correctly all summer long. I had help from a few gentlemen that work on speedo's.
Speedo fix.
Old Dec 29, 2009 | 07:52 PM
gldnkngt's Avatar
gldnkngt
That arm your arrow points to is used to increse/decrease the tension on the hair spring in the speed cup. The proper tension, when combined with the correct strength of the magnet makes sure it is calibrated correctly.
Old Dec 29, 2009 | 08:16 PM
Eddie 70's Avatar
Eddie 70
Ta-da... gldnkngt was one of my biggest helps when I was doing the troubleshooting of this.
To Any speedometer-spezialists out there?
