Pre-lube after rebuild
Old Dec 30, 2009 | 08:14 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Default Pre-lube after rebuild
Okay, this is for you experts out there. I had my engine rebuilt, then broke-in and tested on an engine dyno back in July. The engine builder used the Comp Cams additive for breaking in a flat tappet hydraulic cam. The oil was left in the engine.
Getting ready to fire it up in the next few weeks and I'm concerned about the cam having dried out in the last five months. Would you pre-lube the engine by spinning the oil pump for a considerable length of time, or am I just paranoid?
I plan on having some experienced help to check everything out and fire the engine, but I just don't want to be talked out of doing it....when I really should. Of course, I need to come up with the means to do it. I've seen where an old distributor with the gears ground off can be used, along with a drill.
Old Dec 30, 2009 | 08:29 PM
forvicjr's Avatar
forvicjr
Better to prepare than not, pull the valve covers and do a good 15 min pre oil turning the crank an 1/8 turn every couple of min. Would do this Just before startup.
Old Dec 30, 2009 | 08:59 PM
midyearvette's Avatar
midyearvette
fire it up!!
Old Dec 30, 2009 | 09:16 PM
OMF's Avatar
OMF
Just fire it up and bring the revs up to 1500 right away to get some oil splashing around
Old Dec 30, 2009 | 09:24 PM
72LS1Vette's Avatar
72LS1Vette
You can always just disconnect the spark plug wires and crank the engine for a while to get oil flowing.
Rick B.
Old Dec 30, 2009 | 09:47 PM
WhiteC3's Avatar
WhiteC3
The cam won't get proper lube by spinning the oil pump. Start it up! I store my car over the winter and can be 3-5 months storage. It will be fine.
Old Dec 30, 2009 | 09:56 PM
oleyellar72's Avatar
oleyellar72
Well to be on the safe side, I'd pull the valve covers use a drill to spin a dummy distributor as you were talking about and watch all the rockers lube for a few min. then go ahead an fire it up to about 2000 rpm promptly. Watch her run a while and smile!!! oohh keep a check on oil psi
Old Dec 30, 2009 | 10:45 PM
BLOCKMAN's Avatar
BLOCKMAN
Just priming the engine should get oil to the lobes as the lifters have clearance appox. .002 and enough oil should bleed past the liftes to run down on the lobes.
Old Dec 30, 2009 | 11:25 PM
WhiteC3's Avatar
WhiteC3
It can get some oil. I don't bother with that after winter storage. I have pulled engines apart that sat for years and oil tends to kling to parts pretty well with oil film on cam and some drop hanging yet. But in warmer climates it may differ.
To Pre-lube after rebuild
