71 ls-5 radiator
Old Dec 31, 2009 | 09:11 AM
roger3's Avatar
roger3
Default 71 ls-5 radiator
I am replacing the radiator in my 71 ls-5 (454 365 hp auto).
I purchased a new radiator from Dewitts. The new radiator is only 3 inches thick. The old radiator is 3.5 inches thick. The height, width, and nozzle locations are correct.
Is this right?
Is this okay?
Roger
Old Dec 31, 2009 | 09:51 AM
speedreed8's Avatar
speedreed8
i would call and ask Tom Dewitt, Phone 517-548-0600 Fax 517-548-0602 ,he is the expert, i suspect the new one is much more efficient than the old one.
Old Dec 31, 2009 | 02:05 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
If you got the Direct Fit model, it is a little thinner. It is made of aluminum (versus copper and brass) and supposedly cools 30% better. Make sure your radiator and fan shroud seals are correctly installed. I had to add another thin seal at the top of the radiator, between the radiator and fan shroud to take up that 1/2" gap.
To 71 ls-5 radiator
