Wheel Stud Replacement on rear
Old Jan 6, 2010 | 06:23 PM
dannyman's Avatar
dannyman
Originally Posted by pctgreg
Im going to be honest... With what I just went through doing the kit I would definitly go the route I started too in the beginning by removing the half shaft and pulling the hub instead of attempting to do it with the hub on again. I had 8 hours alone (5 hours on passenger side, 3 on drivers side) just trying to get the pins/locks together with the hub on. I just came inside a bit ago to update the thread.... and all I can say is I am so glad I am done. New studs all around, and new stainless parking brake kit installed. Just waiting on the new cragar lug nuts to come in and she will be back on her feet.
Well done!! One of the worst maintenance issues on your car is finished. Now; if and when you have to bleed your brakes......
Old Jan 6, 2010 | 06:43 PM
pctgreg's Avatar
pctgreg
Cruising
Haha, yeah thats on the schedule for saturday (bleeding the brakes), as well as finalizing the parking brake adjuster under the car since I didn't feel like doing that today. I somehow managed to catch a cold from working in the garage the past few days so I just wanted to get the main stuff out of the way.
Just want to thank you guys again for the help and guidence.
Old Jan 6, 2010 | 07:12 PM
WhiteC3's Avatar
WhiteC3
Originally Posted by wcsinx
Ever ridden a motorcycle?
Q. What happens when you try to come to a stop using only the rear brake?
A. Not f'king much.
Most of your braking force comes from the front brakes, and that chintzy manual drum setup isn't going to apply much braking pressure anyway. I'll get more engine braking just by going to 1st gear.
Now there are cars that actually use the normal rear calipers for a p-brake, and those are marginally useful in an emergency. My old Integra was setup this way, and I actually could lock up the rears and slide with the p-brake. But even then you'll slide for a looooong azz way. You just don't realize how little your rears have to do with bringing you to a stop. Now the ****-poor drum in disk setup found on Corvettes et. al. is freaking useless for anything but parking IMHO.
I would rather have someting than nothing. But Corvettes are broke most the time anyways and who needs brakes if it does not drive. I don't go far when I do drive it.So I guess your right!
Old Jan 6, 2010 | 07:16 PM
zigvs's Avatar
zigvs
And this is how ford does it parking brake on its f 150
Old Jan 6, 2010 | 07:19 PM
WhiteC3's Avatar
WhiteC3
Originally Posted by 71 Green 454
Any tricks on getting the upper and lower springs on. I bought a stainless steel set of springs for both sides. Both of the springs broke on the right side so I thought I might as well replace both sides. It's too cold in the garage now, but I hope I can do it next week.
I put the shoes in place,then get bottom spring first starting at rear shoe. Then hook spring to top hole rear shoe and use a peice of heavy wire to hold forward end of top spring up. Put top of front shoe in place and btween the wire and a good needle nose working through peep hole It gets hooked possibly using a common screwdriver to push it in hole. It a PITA at best.
Note first install pin-springs in front and rear shoes.Good Luck!!!
Old Jan 6, 2010 | 07:20 PM
WhiteC3's Avatar
WhiteC3
Probably works good...
Old Jan 6, 2010 | 07:32 PM
71 Green 454's Avatar
71 Green 454
Thanks for the advice. That's kind of what I had in mind. Everything is in place, I just need to install the springs. I cleaned the adjustment threads so they turn easily. I have the new springs, it's just too cold in the garage to do it....and I'm in Tampa! Yes, I'm a wuss.
Old Jan 6, 2010 | 07:47 PM
wcsinx's Avatar
wcsinx
Well like I said, at least in a manual car, the engine can apply more braking force to the rear wheels than the p-brake. And my car is a manual, so I honestly don't feel the safety of my car has changed much at all.
Old Jan 6, 2010 | 07:54 PM
wcsinx's Avatar
wcsinx
This was the hard part for me. I didn't have any trouble hooking in the top and bottom springs, but I could never get the rear hold-down spring in place because there's now way to manipulate it from behind. Drove me fuggin' -> And I hooked and unhooked the top and bottom spring so much that I ended up snapping the end off one of them. At that point I said screw it, tossed all the parts in a box and there they will stay.
Old Jan 6, 2010 | 08:59 PM
WhiteC3's Avatar
WhiteC3
I have Auto trans. If it were manual I would not care as much. I had a 81 with manual and lost brakes. Sold it after 5 months. three years later thought I would give it another try. This one happened to be auto.
And the parking brake works. It won't stop you quickly but is better than nothing. Yeah the parking brake springs ar a pain it took me four hours to get the top spring on. It took much cursing and few breaks and beer.
