Timing Cover Seal Question
Old Jan 3, 2010 | 09:26 AM
DO2G's Avatar
DO2G
Default Timing Cover Seal Question
I'm replacing my timing chain and have my original timing cover off. Do I also need to replace the seal on the Timing Cover that goes around the crank? If so, any tricks for removal and installation?
Old Jan 3, 2010 | 09:31 AM
imariver's Avatar
imariver
Take the oil pan off and replace everything, you don't want to have to go back and do this all over again a second time. There's a better than average chance that when you disturbe a seal, it won't reseal
Old Jan 3, 2010 | 10:26 AM
JimT's Avatar
JimT
Replace it now, or replace later!
Old Jan 3, 2010 | 10:38 AM
Paul L's Avatar
Paul L
Use the SS sleeve in the kit.
Old Jan 3, 2010 | 01:38 PM
DO2G's Avatar
DO2G
Done....Thank You
Old Jan 4, 2010 | 08:53 AM
jdp6000's Avatar
jdp6000
Punch the old one out. Tap the new one in with a rubber mallet.
I didn't drop the oil pan but it would have made it easier. The bottom one is a bit$h. I put the some rubber gasket on the upper one so it would stick to the block. I installed the cover and held it in place with two of the bolts near the stubs. Loosely installed. I oiled up the big rubber gasket that seats between the timing chain cover and oil pan. I pushed it in with a screw driver and slide the one side up into position then pushed in the otherside with a screw driver. It hasn't leaked.
Jim
To Timing Cover Seal Question
