turn signals dead
Old Jan 3, 2010 | 08:26 PM
bdw3031's Avatar
bdw3031
Default turn signals dead
Hazards work and the fuses are all good. Replaced the electronic flasher on the passenger side.What should I check next.
Old Jan 3, 2010 | 09:23 PM
mds3013's Avatar
mds3013
Do indicators light up but not blink, both left and right? If they light then switch in steering column is working. Are all bulbs good? First thing to let us know. mds...
Old Jan 3, 2010 | 10:55 PM
dannyman's Avatar
dannyman
Separate flasher units for the emergency and the turn signals.
Old Jan 3, 2010 | 11:38 PM
Peterbuilt's Avatar
Peterbuilt
Default Typical turn & 4 way diagram.
Your schematic http:www.nrjvette.com/johdotukset/?c=d;o=d
Old Dec 11, 2012 | 12:26 AM
bdw3031's Avatar
bdw3031
Default Turn signals not working
I checked the harmonica connection and I don't have any power. Any idea where I should check next?
Old Dec 11, 2012 | 01:03 AM
Peterbuilt's Avatar
Peterbuilt
Power for the turn signals goes up the column on the PURPLE, do you have power the both sides of the harmonica connection?
Old Dec 11, 2012 | 01:06 AM
Peterbuilt's Avatar
Peterbuilt
Double check both sides of the fuse first.
Power for the turn signals goes up the column on the PURPLE, do you have power the both sides of the harmonica connection at the "L" connection with the key ON?
To turn signals dead
