noisy 4 speed trans
Old Jan 6, 2010 | 12:01 PM
motorcar's Avatar
motorcar
5th Gear
Default noisy 4 speed trans
Hi guys, I just put together a basket job a 1979 vette and upon road testing. I find that the 4 speed trans is noisy in all of the gears except
4th. Is this normal? Thanks
Old Jan 6, 2010 | 12:38 PM
bashcraft's Avatar
bashcraft
Is it an M22?
Old Jan 6, 2010 | 12:43 PM
motorcar's Avatar
motorcar
5th Gear
yes it is.
Old Jan 6, 2010 | 12:52 PM
bashcraft's Avatar
bashcraft
Then it's normal.
Old Jan 6, 2010 | 01:17 PM
motorcar's Avatar
motorcar
5th Gear
They must have had alot of complaints when the car was new.
Is there any particular fluid I can use to calm down the noise alittle?
I have just regular penzoil 90wt in there now.
Old Jan 6, 2010 | 01:22 PM
bashcraft's Avatar
bashcraft
It's because of the way the gears are cut. M22's have straight cut gears to reduce side loading which increases strength, but they're much noisier.
Old Jan 6, 2010 | 01:23 PM
bashcraft's Avatar
bashcraft
BTW, I don't think m22's were used in 1979.
Old Jan 6, 2010 | 01:33 PM
Rich N.'s Avatar
Rich N.
Default nosiy trans
if it's stock, it's an M-21.
Old Jan 6, 2010 | 01:51 PM
motorcar's Avatar
motorcar
5th Gear
The guy I got the car from tells me the trans is from a 1978.
Old Jan 6, 2010 | 02:04 PM
bashcraft's Avatar
bashcraft
M22's were only produced from 1967-1974.
Old Jan 6, 2010 | 02:44 PM
motorcar's Avatar
motorcar
5th Gear
Ok then, thanks for your help. Looks like I'm gonna have to pull it.
Old Jan 6, 2010 | 02:49 PM
bashcraft's Avatar
bashcraft
I would check to make sure it's not an M22 first. The PO may be wrong. I have a document that should help you ID it. PM me your e-mail and I'll send it to you.
Old Jan 6, 2010 | 05:19 PM
Rich's'78's Avatar
Rich's'78
I believe '78 and '79 used Saginaws. Mine is original, rebuilt when the engine was out (3-2 syncro shot), quiet before and after. If I remember correctly, Sags are easy to spot because they have an iron case and a 7 (?) bolt side cover.
Old Jan 6, 2010 | 06:45 PM
bluthundr's Avatar
bluthundr
Does it sound like this? - http://www.youtube.com/watch?v=7oBGnFzEgxk
Old Jan 6, 2010 | 09:52 PM
gve's Avatar
gve
You could try some Lucas gear lube it quiets rear ends so it should help transmissions,
Old Jan 6, 2010 | 11:12 PM
volition's Avatar
volition
1978 and 1979 L48 cars had a Saginaw 4 Speed case number 3925656.
My 78 has a pronounced noise with it's saginaw in 3 out of 4 gears as well. Almost sounds like a supercharger whine.
I can't tell you if this is normal or not, just that mine definitley has the noise too.
They are referred to as a "muncie" because these oddball units were produced in Muncie, IN instead of Saginaw, MI. So they are Saginaws that are sometimes referred to as a Muncie by documentation.
I suspect it may be a result of a worn center bearing and possibly pilot.
Old Jan 6, 2010 | 11:15 PM
WhiteC3's Avatar
WhiteC3
I had one upon test drive the seller assured me its normal to make noise. I opened it up and center bearing was worn. Repalced it and all was quiet.Also good time to examine clutch system and replace ball stud, throw out fork and anything that is not perfect.
To noisy 4 speed trans
