Reverse lockout T56
Old Jan 7, 2010 | 04:58 PM
Gordonm's Avatar
Gordonm
Default Reverse lockout T56
What are you guys doing for this. Are you just pushing through it or are you wiring it up. I have read anything from a toggle switch to the brake switch to just removing the lockout and hoping to never grind 5th gear.
Old Jan 7, 2010 | 05:30 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
You can remove it. There use to be a company that made a plate. It's just a solenoid with a plunger that lets the shift move all the way over. Trust me you will be missing more 1st to 2nd gears.
Old Jan 7, 2010 | 05:44 PM
Gordonm's Avatar
Gordonm
It would be easy to remove and just make a small plate or one guy used a Dorman plug. I just don't now how easy it is to go into reverse when shifting into 5th. I may need it for clearance also. It looks real tight up there.
Old Jan 7, 2010 | 08:15 PM
Budman68's Avatar
Budman68
St. Jude Donor '07
On a T-56 you will never be slamming into 5th. That would be about 150 mph at high rpms. 5th slides right in, reverse is hard over and up. 6th is a pain.
Old Jan 7, 2010 | 11:35 PM
hap1971's Avatar
hap1971
I wired the reverse lockout to my brake light switch. I can only go into reverse while holding the brake pedal. Works for me.
To Reverse lockout T56
