Conv top questions
1. Is there a difference between the MAD and Ecklers tops? Any other recommendations?
2. Same question for top weatherstriping.
3. The drivers window has a terrible air leak at the back where it meets the top, can I move it back a little by adjusting it in the door? Or, can the top be adjusted to seal better?
4. The two pins pop out of the deck occasionally, can that be fixed?
Thanks,
Joe
Can't remember where I got weatherstripping....I've heard Corvette Rubber is good.
I recall seeing posts on window adjustment on this forum, and/or on the NCRS forums.
I think the pin problem can be solved by adjustment of the mechanism under the deck.
Be aware that upon removal of the original top, you may find significant rust at the header(front of the top frame where it meets the windshield). It is common for this part to rust out. I had to replace this section by having my restorer weld in a new section. You can buy it from most mail orders for around $300.00. Just be prepared.
Regards,
Jim
[Modified by Jim73, 7:22 AM 3/5/2002]
