what headers
Old Mar 5, 2002 | 12:51 AM
Blues77's Avatar
Blues77
Default what headers
what headers will bolt up to my mid-america dual exhaust. Im confused on all the header posts lately, which ones are quality and which ones arent?
Old Mar 5, 2002 | 12:52 AM
Blues77's Avatar
Blues77
Default Re: what headers (Blues77)
also this will be going on 186 gm heads
[Modified by Blues77, 9:53 AM 3/5/2002]
Old Mar 5, 2002 | 11:53 AM
Blues77's Avatar
Blues77
TTT
Old Mar 5, 2002 | 12:10 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
I'd suggest Dynomax ceramic coated headers. You will still need an adapter to go from the collector to your exhaust pipes, you can get that from Dynomax and it might come with the headers. You will still probably have to cut your exhaust pipes to length so they will match up with the collector adapter and the collector. The adapter should be welded to your exhaust pipes, but if you are going to do the work yourself, you can probably clamp them until you can get to a muffler shop and have them welded.
The cutting of the pipes is necessary since the stock exhaust pipes you purchase from Mid-American are designed to bolt on to stock exhaust manifolds, which are much shorter than the headers.
Old Mar 5, 2002 | 12:19 PM
Alwyn678's Avatar
Alwyn678
Default Re: what headers (Smokehouse69)
Old Mar 5, 2002 | 12:25 PM
VETDRMS's Avatar
VETDRMS
actually, i'm pretty sure no full lengh headers will "bolt" up to your exhaust. You'll have to cut the pipe and installt he flanges, or have your local shop do it, shouldn't cost too much :)
good luck :cheers:
To what headers
