Drivers Door ?
Old Mar 5, 2002 | 02:12 AM
76brian's Avatar
76brian
Cruising
Default Drivers Door ?
Is there any differance in a drivers side door from a 73 to a 76? Any change frome coupe to conv.? Thanks for any info. My car was stolen last week. I luckily got it back today but the drivers door is cracked and the frame is bent badly along the bottom of door. Luckily the damage was contained . I have located a door from a 73 and they look exactly the same. Is this the case?
Brian http://www.geocities.com/sixtyninebr...sclassics.html
Old Mar 5, 2002 | 12:22 PM
76brian's Avatar
76brian
Cruising
Default Re: Drivers Door ? (76brian)
I was told by one person that it will work and that the only diference on conv is the glass. Is this true?
Old Mar 5, 2002 | 12:52 PM
Steve Adkins's Avatar
Steve Adkins
I am in the same boat you are. I am looking for a pair of 69 convertible doors and I am wondering what the difference is. I was also told the doors are the same except for a few hardware changes and the glass is different. If you find out the difference between conv. and coupe will you let me know.
Thanks,
Steve
Old Mar 5, 2002 | 04:31 PM
Pete79L82's Avatar
Pete79L82
69 to 77 doors are the same. Replacement doors between a coupe and a convertible are the same. Original doors should physicaly fit but you mave have to make some modifications for some of the hardware. As stated previous the glass is different between coupe and convertible.
To Drivers Door ?
