Mechanical fuel pump for 383 ?
This engine will have around 400-425 HP...
with the
! I have 383 ~425 and installed a new NAPA replacement pump for a 73 Corvette SBC with the vent. The vent works as designed and the motor screams! http://www.summitracing.com/parts/SUM-EDL21/
LT-1 was a fine engine and I'm sure the stock fuel pump was up to the task.
But we're talking about a built 383. If the fuel pump was inadequate and she goes lean at just the wrong time, it could be catastrophic.
The pump I suggested above is only $20 more than a stocker.
Sure seems like cheap insurance and an inexpensive performance upgrade.
As far as the return line, I'd remove it entirely and plug the nipple at the fuel tank.
FWIW
I use no regulator on my 600+ 434 ci
As for the results of "going lean", an inadequate fuel supply at full throttle will cause the engine to suddenly die, and almost stall. It will instantly recover after you let off the throttle. No permanent damage.
I run my system at sub 5 psi and I used to use the bigger needle and seats used for alki burners. Just a little bit of thought goes a long ways. For the record I have had my foot on the floor for over 20 seconds, can you say that?
Something about 30 GPH not being enough. Another way to look at it in fuel needs is what kind of MPG do you get. Lets say that you drive for one full hour at 100 mph and you car has such a wide throttle opening that it only gets 10 mpg. So it took you 10 gallon of gas to go for one hour. Your pump puts at 30 gallons per hour so you are doing great.
Also, according to Holley, a stock fuel pump, which again, flows about 30 GPH, is good to 350 HP. More here:
http://www.holley.com/data/TechServi...ech%20Info.pdf
Using the formula found here:
http://www.fordmuscle.com/archives/2...reOfGetInLine/
...you can see that 30 GPH doesn't do the job, if you're 'exercising' your 400+ HP engine toward it's limits.
This book agrees with me:
http://books.google.com/books?id=lX5...age&q=&f=false
More here:
http://www.chevyhiperformance.com/te...tem/index.html
I could on, but the point is, once you're in he 375+ HP range, you need an upgraded (performance) fuel pump.
The pump I suggested is perfect:
It's about $20 more than a stocker, supplies 110 GPH at only 6 PSI, meaning you don't need a regulator and won't over-power the needle & seat of your Speed Demon carb. The pump's rebuildable and supports 550 HP.
Also, vapor lock shouldn't be a problem on performance engines. By definition, the fuel flows more quickly through the system. For instance, on first gen Camaros (67-69), Holley equipped cars didn't receive the fuel return line (Z-28's, L-78, L-89, and all the 427 COPOs). All other first gens were equipped with the fuel return line.
FWIW
