Which spark plug should I use?
Old Jan 13, 2010 | 07:54 PM
rajsid's Avatar
rajsid
Default Which spark plug should I use?
Folks,
1969 corvette with a GM crate HT 502 motor.
MSD ignition and distributor with 8mm wires.
Cast iron heads.
What type/heat range spark plugs are recommended?
I am getting confusing messages from the internet
GM Performance parts tech specs says - AC Delco R43T
Everywhere else on the internet - AC Delco CR43TS
Are there much difference between these two plugs?
Old Jan 13, 2010 | 09:23 PM
volition's Avatar
volition
They're both the same plug, however a CR43TS has an extended tip (it protrudes farther into the cylinder)
There's differing opinion on both so it comes down to preference. Personally I'd stick with the R43T.
Here's a chart for reference showing you how to decode the plugs:
http://www.acdelco.com/parts/sparkpl...tification.jsp
Old Jan 13, 2010 | 10:01 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
What do the specifications for that particular motor call for ? If it is a crate motor that is still for sale you should be able to find these specs.
If not what plugs were in the motor when you got it ? Extended tip on a motor with pistons not designed for extended tip could be disastrous, however if the specifications for that motor call for an extended tip plug that is the plug I would use
Old Jan 14, 2010 | 12:28 AM
rajsid's Avatar
rajsid
Very interesting chart
Actually the GM Performance parts website says R43T
http://www.gmperformanceparts.com/_r...Long_Block.pdf
Old Jan 14, 2010 | 12:32 AM
rajsid's Avatar
rajsid
GM Performance parts website says R43T, but there are other sites on the internet that recommends the extended type.
I don't remember what was on the car. I paid someone to do a tune up right after I bought the car
I guess I will stick with the R43T.
To Which spark plug should I use?
