Broken Door Handle ??
Old Mar 5, 2002 | 10:48 AM
kleitzel's Avatar
kleitzel
Default Broken Door Handle ??
Hello everybody. YIKES, I squeezed down on my drivers side door handle and heard a "snap" sound. The door does not open! :confused:
I used a flash light to shine into the door, everything looks ok? When I push down on the door handle and release, it springs right back up but the door does not open. Thank goodness I can open the door by using the inside handle. I know what a PITA it is to work on this car, so what kind of things should I be looking for when I remove the interior door panel? Any body ever have this happen to them? Thanks in advance for any suggestions you can offer.
1972 coupe :)
Old Mar 5, 2002 | 10:59 AM
flood's Avatar
flood
Default Re: Broken Door Handle ?? (kleitzel)
I just had to replace the interior handles on mine. The door panels are fairly simple and straight forward. I would think you could see the problem once you get in there. I haven't had to mess with the exterior handles but when I got the door panel open it was all right there. The linkage to the inside may have just broken or came undone.
Old Mar 5, 2002 | 11:25 AM
GTR1999's Avatar
GTR1999
Door handle/latch problems are quite common on C3's. Does the door lock work? The best thing to do is remove the door panel and look at the latch assembly as the handle is pushed down,you should see what happening then. The outside handle has a rod going down to the latch and connects to a arm off the latch. There is adjustment there on the threaded end of the rod.What I have found that works the best is to remove the latch assembly and clean it with brake or carb cleaner-get all the dirt and grease out. Use white grease to lube it again and reinstall it. Then adjust the throw on the outside rod do this with the door open so you don't get it stuck closed. Use a screw driver to latch the door when adjusting. With a little time you'll get it and it should work as good as new. If you find something broken you should be able to find new parts from most of the vendors,or I would call Gary Gruhala.
Good luck,
Gary
Old Mar 5, 2002 | 11:46 AM
kleitzel's Avatar
kleitzel
Default Re: Broken Door Handle ?? (gtr1999)
Thanks for the info. I'll have to remove the door panel to see what's up. I have a spray can of the white lithium grease, is that what you use to lube everything up? By the way, the door lock does not work from the outside or the inside.
Old Mar 5, 2002 | 12:34 PM
Kingt's Avatar
Kingt
From your description it sounds like one of the plastic retainers that secure the linkage rods may have broken. But who knows until you look inside. Hope you have small hands!
Old Mar 5, 2002 | 05:56 PM
GTR1999's Avatar
GTR1999
Yeah, I used the srpay stuff before and it works ok. Also check for the rods form the inside handle binding against each other. I found this on my 69, the ends are 90* and adjustable. One of mine was bent and causing part of the problem.
Gary
Old Mar 5, 2002 | 06:18 PM
GaryS's Avatar
GaryS
this is a very easy repair. As others have stated, pull the interior hardware off, then the panel, and finally the plastic shield. Start at the back of the door and start looking for loose hanging rods. Most likely you snapped a clip retainer. Just about everybody carries them. My friend picked up a handful of them at an auto paint store. You have separate rods for the interior door release and the exterior door release. Just look for the rod that either isn't connected or isn't working when you push down on the exterior door handle.
Gary
Old Mar 5, 2002 | 06:46 PM
vettesite's Avatar
vettesite
Be careful you don't get zapped :eek: if your Vette has a factory alarm, power windows, or locks. I was using a screw driver to install the C clip that holds the lock on and I grounded a wire BBZZZZZZT! Scared the poop out of me. I learned my leason and I disconnect the battery when I work on the doors. :yesnod:
Old Mar 5, 2002 | 10:00 PM
HFP073's Avatar
HFP073
I think I have the same problem. I checked the Haynes manual about removing the door panel and it says to use a special tool. Do I need this or can I just pull it off (after I remove any screws)? I know I am a bubba :yesnod: :yesnod:
Old Mar 5, 2002 | 10:46 PM
FERL 73's Avatar
FERL 73
Check out my door thread (with some photo's) http://forums.corvetteforum.com/zerothread?id=168520
I repaired mine just before I took the vet in for winter storage. Like usual it bones me just as i put it away for the winter. The door handle works fine but I had trouble unlocking the door from the inside. I need to address that problem when the weather breaks. I took the precaution of using a screw driver to test the funcionality without actually closing the door. That went like a charm but then I ran in to the unlocking problem. After you have repaired the latch I would test everything out before putting the door panel back on.
To Broken Door Handle ??
