Replacing tach cable
Old Jan 14, 2010 | 08:39 PM
roger3's Avatar
roger3
Default Replacing tach cable
I need to replace tach cable in my 71 ls5. Do you have to take dash out or is it possible to do it with dash still in?
Old Jan 14, 2010 | 09:22 PM
oldsarge's Avatar
oldsarge
It is possible. You can reach up around the column, push in the release and pull out cable behind dash. It is a bit of work, but it can be done. I laid on my back btwn the seat and pedals and could reach up in behind. Good luck and watch your back.
Old Jan 14, 2010 | 10:24 PM
roger3's Avatar
roger3
Oldsarge,
Thanks for the info. I will give it another try tomorrow, hopefully with success.
Thanks again
Old Jan 14, 2010 | 10:28 PM
1974ta's Avatar
1974ta
Let me just add it is easier to have a second pair of hands to assist in pulling it as you release the clip. Small hands help.
My 13 yo son helped.
Bill
Old Jan 15, 2010 | 08:15 AM
roger3's Avatar
roger3
Bill
I have one of those (he's actually 14) that I use quite often. Sometimes works well, sometimes is a little cranky.
Old Jan 15, 2010 | 10:06 AM
jackson's Avatar
jackson
All good suggestions
I'll add ... remove driver seat ... just a few bolts ... gives you loads more wiggle room & kinder to your aching back ... heck you might find "lost treasure". Also, roadsters have additional bracing beneath dash & that's just more stuff in the way. If you're replacing core only, it has an OE ferrule crimped to gage end of core ... thus core can be pulled/inserted only at gage end. Also, suggest loosen (don't drop) column & loosen driver's gage cluster ... replace all those small lite bulbs while you're in there & that'll also help facilitate the cable change. Pay close attention you don't leave any vacuum lines / wires knocked loose. Got bandaids & a stiff drink?
FYI, both my 71 used Wagner p/n 168 bulbs in cluster. They're clear colorless push-in bayonet. I don't recall how many, but last time I got a box of 10 from local parts store & used most of em.
Old Jan 15, 2010 | 10:31 AM
roger3's Avatar
roger3
Thanks Jackson,
It is a roadster, and I do have the seat out. You are dead on, it's crowded and tight under the dash. When I first put my hand up in their it was very tight, now I seem to have more room for some reason. I suspect I accidentally disconnected something so I will have to check it closely. I am using my wife's compact makeup mirror to see around in their, it's a merle norman 3 1/2" round, works perfect. All my lights are working at the moment so I will probably leave well enough alone for now.
This summer I will need to take the gage section out to fix/replace the oil line to the oil pressure gage, it isn't working at the moment. Hopefully the line is just plugged up.
Thanks again,
Roger
Old Jan 18, 2010 | 12:36 PM
roger3's Avatar
roger3
Pulled old cable out - It's not broken, but is pretty hard to turn.
Connected new cable to tach - spin by hand - tach works
What parts in distributor are biggest suspect? Are these parts usually available?
Old Jan 18, 2010 | 03:08 PM
694speed350's Avatar
694speed350
main shaft and the cross shaft that the cable connects to and yes parts avaible.
Old Jan 19, 2010 | 12:11 AM
jpg71vette's Avatar
jpg71vette
Default blindly
you can but its hard lookup in there with a wirror and tiny flashlight, LED
To Replacing tach cable
