Update on squeak and tire lean
Old Jan 15, 2010 | 05:10 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Default Update on squeak and tire lean
Had a squeaking noise from the rear that went away before I could find it.
And my rear pass. tire was leaning in.
Bad u-joint on the pass side half shaft.
Old Jan 15, 2010 | 05:39 PM
71coupe454's Avatar
71coupe454
That may well have been your squeaker to but I am trying to picture how the u-joint made your wheel lean? I have only been around the rear end of my car long enough to install brake lines and mount new tires and wheels.
Old Jan 15, 2010 | 08:09 PM
WhiteC3's Avatar
WhiteC3
The half shaft supports the spindle/rear end of trailing arm to some degree. If you (god forbid) had a u-joint break the wheel would fold inward. I never had that happed but it would suck!
Hope this helps...
Old Jan 15, 2010 | 10:13 PM
71coupe454's Avatar
71coupe454
Ok I see, I guess next time I look under there it will be clear, I was thinking the only forces on the u-joints was to turn the wheels. I'll be under there soon to try some longer bolts to get a little lower... I learn something every time I open this page, Thanks
To Update on squeak and tire lean
