Gauge lights don't work. Please help.
Old Jan 18, 2010 | 10:21 PM
coll1446's Avatar
coll1446
Default Gauge lights don't work. Please help.
I have a 1970 Corvette and I'm having problems with the interior gauge lights. They don't turn on. I recently replaced the headlight switch and changed all the interior bulbs to leds, but that didn't work.
I was told to put a ground on the switch. Any other ideas? Any help would be greatly appreciated.
Old Jan 18, 2010 | 11:22 PM
wrw2497's Avatar
wrw2497
do the parking/running lights work...they are on the same fuse....is all the wiring stock...anyone tapped into for radio or.....
Old Jan 19, 2010 | 10:43 AM
PhyscoVette's Avatar
PhyscoVette
you need tp pull the assemblies apart and check the circuit bords they are known to have small breaks in them.
Old Jan 19, 2010 | 11:55 AM
Peterbuilt's Avatar
Peterbuilt
Default Ground Wire
Did you check to make sure that the 'Harness Ground' (HARN GD) wire is connected to the drivers side hinge post?
Old Jan 19, 2010 | 08:28 PM
...Roger...'s Avatar
...Roger...
The INST fuse must be hot when the light switch is pulled out and rotated counterclockwise , is it ?
(The headlight switch being grounded is for the interior lights but has nothing to do with the dash lights.)
Old Jan 20, 2010 | 10:34 PM
coll1446's Avatar
coll1446
yes the running lights do work & yea it looks stock... weird huh?
Old Jan 20, 2010 | 11:29 PM
wrw2497's Avatar
wrw2497
Default lights
O k...they worked before the switch and bulb change ???...try one of your old regular bulbs...led's are polarity sensitve,only work one way....(just a test)...add a ground wire to the metal part of the switch....(behind dash) hope your dash is open..then try lights....is the switch a repro from ecklers ??
To Gauge lights don't work. Please help.
