78 L48 Plug Wiring Question
Could someone share a picture of what retainers hold the plug wires in place on a 1978 L48? Specifically, after the wires exit the rubber retainers at the rear of the block and circle around under the manifold I think there are some sort of plastic tabs that are mounted on small braces that hold the two rear wires shortly before they connect to the spark plug.
Any help is appreciated!
Dan
Gary
http://www.zip-corvette.com/Default.aspx?
The FRONT 2 plug wires do attach to a 2 wire clip bolted to the block below the plugs. Front wires come in from below. There's also the V shaped shield for the fronts.
Here's a pic of the clip you're thinking of on the fronts. Cropped it out of another pic.
