Need accurate test for tach drive system.....
What is the easiest way to see what is the culprit in the system? Is it as simple as disconnecting the cable from the distributor and spinning it to see if the tachometer responds? Can I disconnect the cable from the back of the tach and spin the input shaft and check for a response? What method(s) will give me accurate results? Thanks!!
Weasle
Trying to get it off the back of the tach might be tuff.
[Modified by James, 4:03 PM 3/5/2002]
If I recall correctly (y'all pounce if I'm mistaken), distributor mainshaft runs at half speed of crankshaft. I'm certain that tach output coupling runs at 1:1 ratio to distributor mainshaft. So, if engine is running at 1000 rpm then distributor is turning at 500 rpm and tach output coupling is turning at 500 rpm while tach will register at 1000 rpm. So, tach registers at double its input rpm. To help diagnose the cable and/or tach, first try this: Disconnect tach cable from distributor coupling, carefully-gently chuck cable end into REVERSIBLE drill motor, spin drill in reverse (facing chuck it should turn clockwise). Many drills'll turn about max 600 rpm, so your tach should register about 1200 rpm (or twice the speed of your drill). When driven by drill ... If your tach needle doesn't move or if it bounces ... then you know you've got a problem with cable and/or tach ... but you may also have a problem in the distributor too. Distributor's tach gears are difficult at best to see into when on engine. To properly inspect the distributor, I suggest you pull it from motor, clean out the grease&gunk from tach gears and closely inspect on benchtop. In addition to stripped crossgear, the gear cut into the mainshaft can be chewed up/flat-spotted. Hope this helps.
Jack
