question about fixing the headlight vacuum tree
Old Jan 19, 2010 | 06:26 PM
another-user's Avatar
another-user
Default question about fixing the headlight vacuum tree
i repaired one tree already with O rings and all, but apparently didnt do it correctly. the green port i can get upto about 10hg, but it wont hold vacuum. the red port will barely spike to 5hg and it drops off instantly.
ive got a 2nd tree here that im going to try again on, but ive got a question.
is the foam supposed to do anything other then keep crap out of the tree? im wondering if i have too thick of foam in it, and the foam is supposed to be able to compress and help seal off the system.
Old Jan 19, 2010 | 06:55 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
The foam is only a filter. As long as it is open cell foam and you can get air thru it you should be fine.
Old Jan 19, 2010 | 07:02 PM
another-user
thats what i thought. time to try the O rings again. maybe ill try glueing them on, and coating them in rtv silicon.
To question about fixing the headlight vacuum tree
