never overlook the easy answer. After spending lots of time under the hood, I found the answer inside. The vac/electric switch was pushed back lacking 1/2 of even touching the brake pedal. Duh
So what was the original issue? Not working? I am needing to get mine going as well.....
Reason: spacing...syntax
Cruise not working was original issue. With the switch pushed away from the pedal the system believed my foot was always on the brake. I favor the other pedal though.
