MSD Ignition Install
Old Jan 20, 2010 | 11:32 AM
Trip 69's Avatar
Trip 69
Default MSD Ignition Install
Has anyone ever put the MSD 6AL up under the dash on the passenger side of a '69 427/435?
I am concerned about heat. I put foil insulation down before my new carpeting which seems to help quite a bit. I've driven on really hot days in the summer and it's not bad.
I'm trying to keep a "clean classic look" under the hood but don't want to mess the module up.
Old Jan 20, 2010 | 11:45 AM
pws69's Avatar
pws69
Many have - one of the more convenient places....
Old Jan 20, 2010 | 12:48 PM
eastltd's Avatar
eastltd
Here's an alternative location that worked well for me:
Old Jan 20, 2010 | 12:58 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Thats where I installed my MSD box. I've even got it positioned more outboard and up towards the fender top. You have to look hard to see it. Plus it gets the cooling from the fender vent. About 8 years now with many miles. No problems.
Old Jan 20, 2010 | 01:55 PM
roscobbc's Avatar
roscobbc
on my '68 I have MSD 6T there + soft touch rev control + rotary add-on control.
Old Jan 20, 2010 | 02:19 PM
Roughrider's Avatar
Roughrider
That's exactly where I installed mine on my '69 427/435. It works well. Summit sells an installation kit hat makes it a snap. Removing the panel is pretty easy as well.
Old Jan 20, 2010 | 03:01 PM
Trip 69's Avatar
Trip 69
To all...thank you. I'm going to do the Summit install kit hat. Can't wait to get the ignition installed and running.
Old Jan 20, 2010 | 03:05 PM
Trip 69's Avatar
Trip 69
pws69 - I live on the north shore...will be workin' in Marlborough this summer...
Old Jan 20, 2010 | 04:21 PM
kortensi's Avatar
kortensi
Put mine there also. You can make your own brackets relatively easy.
Check out this page about a 1/3 of the way down.
http://forums.corvetteforum.com/c3-g...1-pics-30.html
KO
Old Jan 22, 2010 | 09:12 PM
Ray Y's Avatar
Ray Y
I see you kept the stainless braided wires. Did you re-sleeve new MSD wires or are these early generation noise suppression wires? I like the look of the vintage wrapped wires.
Old Jan 22, 2010 | 09:40 PM
spinadog's Avatar
spinadog
That's two of us - I'm also curious...
Old Jan 22, 2010 | 09:51 PM
eastltd's Avatar
eastltd
Those are reproduction noise suppression wires.
I like the look too:
Notice how the MSD box disappears
Old Jan 23, 2010 | 10:26 AM
TheycallmeDave's Avatar
TheycallmeDave
Instructions say to locate where it will get PLENTY of cool air over the box cause it runs hot. On my 1970 , my MSD6 box sits IN FRONT OF the radiator down on the valance (fastened in place) . The MSD6 I got was the waterproof model which is internally coated / totally sealed to prevent moisture from getting inside and vibration proof . Of course you need to extend the wires from this location back to the Distributor but thats no problem . Instructions also say to mount the Box as far away as possible from the radio so interference is eliminated. I ran the wires very neatly and it does not detract from a clean appearance. The MSD really made a difference on mine thru much hotter spark, better idling, no foul plugs , and crisper performance.
Old Jan 23, 2010 | 11:29 AM
Ray Y's Avatar
Ray Y
Thanks Ian! That is one clean motor.
Old Jan 23, 2010 | 02:39 PM
eastltd's Avatar
eastltd
No problem Ray,
Glad you like the motor.
To MSD Ignition Install
