How would you fix this crack?
Old Jan 21, 2010 | 08:39 PM
FlaVert's Avatar
FlaVert
Default How would you fix this crack?
This is the seam between the firewall and floorboard on a 68. It looks like the firewall took a shot from the outside and whatever was in this seam fell out. What should I use to fix it?
Thanks,
Rick L.
Old Jan 21, 2010 | 08:42 PM
rcread's Avatar
rcread
One can fix anything with duct tape and/or JB Weld.
Old Jan 21, 2010 | 08:52 PM
csradley's Avatar
csradley
I would clean that out really well and use seam sealer on it or if your really worried about re-bond and seal the crack with 3M or Lord Fusor panel adhesive/bonding adhesive.
Good luck.
Old Jan 21, 2010 | 08:54 PM
tarheeljww's Avatar
tarheeljww
my 71 did the same thing.....only worse.
I put a layer of glass on the floorboard and ran it up, and wraped it around, back toward the door, then cut a piece to run down the valley, as thats where mine came apart as well.........holding so far.
goodluck,
Jw
Old Jan 21, 2010 | 09:25 PM
crf311's Avatar
crf311
If you don't fiberglass it, you coud use some panel adhesive. Put the adhesive in the crack, then put a jack under then floor and lightly push up on the floor. Will cure in about half hour.
Old Jan 21, 2010 | 09:27 PM
dannyman's Avatar
dannyman
Seam Sealer.
Old Jan 21, 2010 | 09:40 PM
MIKE80's Avatar
MIKE80
Use seam sealer or marine grade sealer.
http://www.3m.com/product/informatio...e-Sealant.html
Old Jan 22, 2010 | 10:17 AM
FlaVert's Avatar
FlaVert
Ordered some 3M 8115 last night.
Thanks for all the replies!
Rick L.
To How would you fix this crack?
