Valve Springs
Old Jan 23, 2010 | 01:13 AM
jordan89's Avatar
jordan89
Default Valve Springs
I have to install the valve spring height and need help choosing spring shims for the springs. The springs have an outside diameter of 1.260in. and the only shims I see that come close to that diameter are 1.250, so will these spring shims work on the 1.260in. diameter springs I have? I can't find any spring shims that are the same diameter as the springs.
Old Jan 23, 2010 | 02:42 AM
Solid LT1's Avatar
Solid LT1
Give S&S Automotive in San Leandro a call they can help you out with quality parts and possibly labor if you need it.
Old Jan 23, 2010 | 06:31 AM
Gordonm's Avatar
Gordonm
Yes they will work fine. You are only talking about .010 inch. That will be supported fine.
Old Jan 23, 2010 | 12:04 PM
jordan89's Avatar
jordan89
I'm going to see if I can find their number online and give them a call.
To Valve Springs
