Conversion to 1/2" fuel supply line ?
Old Jan 23, 2010 | 10:38 PM
Ray Y's Avatar
Ray Y
Default Conversion to 1/2" fuel supply line ?
I know some of you guys have moved up to a 1/2" fuel supply line to quench the thirst of big cube motors. Did you drill out the stock 3/8" line on the fuel sending unit, or weld in a new AN -8 fitting directly on the tank? If the later, how did you close off the original 3/8" pick up tube on the sending unit? Same basic issue/question for the return line. I have a BB set up now with the std 1/4" return. I plan to buy a new tank and then build it up.
Thanks for any ideas or photos.
Old Jan 23, 2010 | 11:26 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You can do it several ways. Some folks just remove the original pickup tube and after enlarging hole..they install a -8 bung fitting into the original fuel sending unit. No welding required...or you could just weld a steel bung in same spot.
I added a fuel sump to mine and ran 2 -10's out of it to a *Y* fitting and then into the pump, then -10 to the regulator. I ran a -8 return back to the top of the tank with a bung fitting.
My stock outlet in fuel sending unit was sealed off with a rubber cap and a clamp. Been that way for years....but someday I'll just weld it solid to eliminate a potential leak.
JIM
Old Jan 24, 2010 | 02:59 PM
Ray Y's Avatar
Ray Y
Thanks Jim!
I haven't made it back to TX since we talked back in Oct when I was in town. Take Care!
To Conversion to 1/2" fuel supply line ?
