Borgeson Conversion
Old Jan 25, 2010 | 10:31 PM
michalbugno2006's Avatar
michalbugno2006
Default Borgeson Conversion
I am converting the stock power steering to the Borgeson kit. I finally got the pitman arm off (took a solid 6 hours) and control valve (took and hour) and have noticed the threads on the relay rod are bad, what size is this so I can try to get a dye for it and try to clean them up? I'll try to do a short write up when I finish. Thanks!
