When to change spark plugs
Old Jan 26, 2010 | 05:25 PM
buffed1978's Avatar
buffed1978
Default When to change spark plugs
I have only driven my vett 15000 miles in the last 10 years I have not changed the plugs since then.Every things runs good should I change them or let them go for a while longer.Its a big job to change them because I have sidemount headers and I have to remove them just to pull the plugs.I could check one on each side because that is all you can pull without removing the headers.
Old Jan 26, 2010 | 06:38 PM
71coupe454's Avatar
71coupe454
Old Jan 26, 2010 | 10:38 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
well if the car is running well you could leave them alone.....and if it starts to miss then do it.
Old Jan 27, 2010 | 06:38 AM
Golden's Avatar
Golden
Old Jan 27, 2010 | 10:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I would check one, but you'll feel it under your right foot when they need to be changed.
Old Jan 27, 2010 | 02:48 PM
MelWff's Avatar
MelWff
why do your have to remove the headers to change the plugs? I have a 69 with side pipes. Using a combination of box end wrenches, standard spark plug socket or modified spark plug socket with only 5 sides I can change all the plugs.
Old Jan 27, 2010 | 03:08 PM
TWINRAY's Avatar
TWINRAY
The only concern I'd have with leaving them in that long is them fusing to the block and wiping out threads when you (or whoever) decides to finally get them out
To When to change spark plugs
