Power Steering Pumps/Pulleys?
Old Jan 26, 2010 | 09:27 PM
cart3113's Avatar
cart3113
Default Power Steering Pumps/Pulleys?
I want to put power steering on my 69 SB. All of the kits show a listing for a non high-performance and a high-performance pump. I think this has to do with the pulley but I'm not sure. Can someone tell me if that is the difference? My block is not the original but is coded to be of the same casting numbers and I have double hump heads. I'm not sure if that would be the same as the L-46 as far as the power steering pump and pulleys are concerned.
Thanks for any help,
Jim
Old Jan 26, 2010 | 09:39 PM
LT-1 kid's Avatar
LT-1 kid
Hi Jim, the only difference that I know of is if its a BB or Sb, the brackets are different, also some high hp solid lifter motors with big oil pans did not have ps.
Old Jan 27, 2010 | 11:28 AM
cart3113's Avatar
cart3113
Thanks for the information. I called VBP today and got the tech dept. The only difference is the pulley. The hypo uses a cast pulley the non-hypo uses a stamped steel pulley. The stamped steel is good up to 400hp.
Old Jan 27, 2010 | 12:04 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I'd take a look at the Borgeson conversion. I'm doing my car right now and it's slick! Gets rid of the funky Vette PS cylinder with a much improved steering box and they can provide the correct brackets and pulleys to make it a bolt on deal. Great people to work with!
JIM
Old Jan 27, 2010 | 12:33 PM
cart3113's Avatar
cart3113
The Borgeson unit looks good. Price is right for a complete kit. How are you shortening the steering shaft?
Old Jan 27, 2010 | 01:04 PM
Solid LT1's Avatar
Solid LT1
Difference in SB applications is whether it has A/C or not.
Old Jan 27, 2010 | 02:20 PM
427Hotrod's Avatar
427Hotrod
The '69 will have a collapsible column....so you just *tap* it back toward the steering wheel with a hammer.
Cut off wheel/chop saw works on '63-66 cars.
JIM
Old Jan 29, 2010 | 10:47 AM
cart3113's Avatar
cart3113
Looks like this may be the way to go for me. I have installed the VBP front end kit so everything in the front suspension is new. I believe the Borgeson unit will be much easier to install and I won't have to worry about the ground clearance issue.
Thanks again for your help
Old Jan 29, 2010 | 11:08 AM
hugie82's Avatar
hugie82
When I did my Big Block conversion I found DocRebuild had every little spacer, nut, brackets and pulley for an OEM install for all older vettes. The price was good too.
To Power Steering Pumps/Pulleys?
